Old 05-04-2017, 03:55 AM
DanielG141 DanielG141 is offline
Default Edit Window Not Fully In View
I'm having problems with the edit window not being fully in view in Pro Tools in Windows 10. As the edit and mix windows aren't separate from the main Pro Tools application window it seems very hard to rectify this problem. Any help would be greatly appreciated.
Old 05-04-2017, 04:37 AM
Drew Mazurek's Avatar
Default Re: Edit Window Not Fully In View
Are you zooming (or whatever Windows calls it) your screen?
www.drewmazurek.com
Old 05-04-2017, 04:40 AM
Are you referring to the DPI scaling? I've checked that out on having it on and off and it doesn't seem to change it. The top part of the edit window is out of view so I cant reach the options for closing and fitting to window etc
Old 05-04-2017, 04:43 AM
What screen res are you using?
www.drewmazurek.com
Old 05-04-2017, 04:53 AM
1920x1080 on a 14" laptop
Old 05-04-2017, 10:36 AM
nigelpry's Avatar
nigelpry nigelpry is offline
It's been a long time since I used windows, so sorry if this is a daft comment, but ...
If the top of the edit window has disappeared in the way you describe, does the main PT window not give you a scroll bar on the right hand side so you can scroll up to get to the top of the edit window? Maybe there is some option now in Windows 10 prefs that you have change to stop that scroll bar being suppressed if it doesn't appear?
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Old 05-05-2017, 07:40 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
A screen shot would have been great, but see if this can help:
Trash prefs, then create a new PT session. That should give you the default presentation, which you can then organize the way you want. Hopefully, any other session should open with your new window settings.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Is there a way to automatically bring a track you select into view in the edit window Focuret Artist Series 4 01-05-2013 01:48 PM
PT 9.0.1 Edit window view jumps forward collinsylex macOS 2 02-10-2011 12:58 PM
View-Other displays-track list and regions list, only from edit window? crizdee Pro Tools TDM Systems (Mac) 0 02-27-2009 10:46 AM
View Selected Region in Edit WIndow? blastula Pro Tools TDM Systems (Mac) 2 03-20-2008 05:16 AM
Change view sizes quickly in Edit Window Mason00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-03-2005 10:56 AM
