Old 07-05-2015, 03:02 PM
gtodd876 gtodd876 is offline
Default No Audio Output from Only Analog 1-2
I'm using a RME UCX audio interface and I suddenly don't get audio output from Analog 1-2. If I use other programs like Ableton Live my Analog 1-2 (software playback channels) works great so I can rule out hardware/firmware issue. Only having this routing issue with Pro Tools 11. If I switch to Output 3-4, 5-6, 7-8, then the audio cuts back on, it works great. Only Analog 1-2 seems to cut out audio. I have checked my IO settings so many times and nothing has changed. Seems like its a stupid mistake somewhere in PT but I can't figure it out. I have also tried a computer restart.
-Todd
MBP Mid 2012
RME Fireface UCX
PT 11.3.1
http://vimeo.com/channels/gtmbass
Double Bass Live Looping
Old 07-05-2015, 04:50 PM
Default Re: No Audio Output from Only Analog 1-2
I have also tried a reinstall of PT 11 and it did not help the problem.
Old 07-05-2015, 05:32 PM
Are all your tracks actually assigned correctly?(the photos look correct for the IO setup)
Old 07-06-2015, 06:47 AM
Yeah my tracks are assigned correctly. I attached a couple pictures to show this strange behavior. Maybe next step is to see if I have a corrupt pref file that stuck around even during the reinstall?
Thank you for the help!
-Todd
Old 07-08-2015, 04:35 PM
This is so weird. Still have same issue. All other software works fine with my interface. Only Pro Tools won't spit out audio on Analog 1-2. I have no idea what to do at this point other than complete reformat. That would be such a PITA.
-Todd
Old 07-08-2015, 05:08 PM
Drew Mazurek's Avatar
Your screen shot cutoff where the Monitor Path icon would be on the Buss page.
www.drewmazurek.com
Old 11-13-2022, 05:05 PM
JohnTyler JohnTyler is offline
Sorry to necro the thread, but I'm having the same issue. I have an RME Madiface XT and am running Pro Tools Studio Version 2022.10.0 on Windows 11. Pro Tools sends audio to audio channels 1 and 2, but not to the specifically designated "Analog 1 and 2" that the speakers are connected to (the physical outputs on the back of the Madiface XT). The strangest thing is that when I route Pro Tools audio to audio channels 1 and 2, Pro Tools sends the audio to both my monitors AND what I have connected to audio channels 1 and 2 (which is currently an external input into my SSL Big Six mixer).
Was this ever resolved? Thanks,
John
Old 11-13-2022, 09:13 PM
Top Jimmy's Avatar
John
I would try completely rebuilding all I/O paths. Try deleting all paths and then use the default button to restore the paths defined by the interface. Do this on the input, output, and bus tabs and then see if you still have a problem.
James Cadwallader
Old 11-14-2022, 06:11 PM
smurfyou smurfyou is online now
John
I don't understand your routing but it sounds like an issue in RME TotalMix. Do you have it set to DAW mode or the full mixer mode?
~Will
Old 11-15-2022, 10:24 AM
The Weed's Avatar
The Weed The Weed is offline
This ^^^^
If you're not in DAW Mode in TotalMix, Pro Tools will output to the Software Playback - the middle layer in TotalMix - and you need to route that Software Playback to Analog 1/2 Out in TotalMix, which can be done in Matrix.
TotalMix is great, but does take some thought.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Monitor output or Main Analog Output? A_alRumaidh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-17-2015 07:19 AM
Adat output louder than analog output ? sanzrodrigo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-03-2010 11:42 PM
DIGI 003 Factory - No Analog Audio Input / Output travisgregorash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-08-2007 08:53 PM
7.3 still has the core audio mirror analog output BUG! WHEN? dkstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-09-2007 10:02 AM
Interfacing 888 analog output with analog console Siegfried Meier Pro Tools TDM Systems (Mac) 3 09-12-2003 01:26 PM
