Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 01-05-2015, 12:58 PM
DeeJayEhh DeeJayEhh is offline
Default Mbox 2 Pro, pt11, windows 8.1 hardware not recognized.
Hi all,
Im running an mbox 2 pro, with pt11 on windows 8.1
Windows recognizes and can use my interface.
Protools will not. I can boot up protools using my onboard sound card and it even sees the hardware (mbox 2 pro is listed on the hardware page) but I cant assign anything in the I/O setup to the mbox 2 pro.
I've gone through the windows 8 optimizations, dug through every forum post and suggestion I could find. Protools will run fine with onboard soundcard. So I fairly certain pt is having trouble accessing my interface.
I've tried running the most current drivers and pt updates. Tried rolling back to older versions of the driver and pt 11.2. Always the same results.
Any suggestions would be appreciated.
Thanks,
Dylan
Old 05-12-2015, 04:39 AM
Cale Cale is offline
Default Re: Mbox 2 Pro, pt11, windows 8.1 hardware not recognized.
I am suffering from the same issue, however with an Mbox 2. I'd appreciate assistance.
MBox 2 hardware not recognized. Skau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-18-2014 11:05 AM
Can't activate PT11-mbox serial not recognized JonWillford Pro Tools 11 6 12-15-2014 10:29 PM
Mbox 2 hardware not recognized on v 6.7 esighinfo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2007 09:26 AM
Mbox 1 hardware not recognized....???????? Slowboat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-04-2005 08:17 AM
HELP!!! PLEASE! MBOX Hardware not recognized!!!! RJ7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-05-2005 10:38 PM
