Old 02-23-2014, 02:18 PM
raywinn1 raywinn1 is offline
Default Protools 11 Menu Bar Trouble
I'm having some trouble between my Main Computer and a new Laptop that I purchased.
When starting Protools 11 on the laptop it opens fine Full Screen at first and I see all of the Menu Options, but when the option comes up to open a session the whole protools window shrinks down to a much smaller size and the Toolbar across the tops is partially hidden. I then have to drag the window to full size, but the Menu Bar is till partially hidden and very hard to read.
See Attach photo.
Hope some one here can help
Ray
Old 09-18-2014, 07:58 PM
riel777 riel777 is offline
Default Re: Protools 11 Menu Bar Trouble
Hello, I'm having the same issue. If i start a new session, the menu options show. The next time I start a new session, the menu options show half way again. Have we found a solution? Thank you!
Old 09-19-2014, 04:18 AM
Neither of you say what computer and operating system you're running which is unfortunate. Either way - are either of you using onboard graphics versus a separate graphics card? PT doesn't like onboard graphics. How much ram do you have in your computer? Onboard graphics typically steal the ram they use from system ram and if you're short on that or ram is going bad then you'll have issues. Have either of you deleted any fonts from the system?
Jack
QAPLA!
Old 09-20-2014, 11:11 AM
Thanks musicman691 for the response. I apologize for not including my system info. My system info:
Dell XPS L501x Laptop, Processor: Intel Core i7CPU Q740 @1.73GHz Ram 8.00GB, Video (0nboard) GPU processor: NVIDIA GeForce GT 435M
OS-Windows 8.1 Pro (64bit), Audio Device - Focurite 6i6, Pro Tools v11.2.1
I haven't deleted any fonts.
Thanks
Old 09-20-2014, 01:53 PM
Thanks
Amount of ram looks good but that cpu is way underpower for running PT. Laptops are always a crapshoot for running PT. Are you running the display at the normal resolution recommended for it? All displays have a resolution called 'native' that is the best for that particular display. Have you looked at the system requirements for running PT11 on Windows? If you haven't I'd suggest taking a look at that.
Jack
QAPLA!
Old 12-27-2014, 03:03 PM
Dalmer Dalmer is offline
I found that if I "Disable display scaling on high DPI Settings" in compatibility settings fixed it for me.
Old 01-23-2015, 12:27 PM
Thanks for the suggestion! This will work for me for now until I upgrade my system.
Old 05-29-2018, 10:52 AM
Well just to follow up after 4 years, till this day after upgrading I still need to check DPI setting for the menu bar to appear properly.
Processor: Intel Core (TM) i7-7700HQ @ 2.8GHZ
RAM: 16.0 GB
OS: Windows 10
Old 09-27-2022, 05:54 PM
pianomanharry pianomanharry is offline
Years later... If anyone reading this still needs help. I am running Windows 10.
1. I have Pro Tools shortcut on my desktop so I right click on the shortcut and go down and click "PROPERTIES".
2. Click the "COMPATABILITY" tab.
3. Click down the bottom where it says "Change High DPI Settings".
4. At the bottom where it says "High DPI scaling override", make sure that "Override high DPI scaling behavior" is checked and make sure the drop down box says "Application". Click OK.
That did it for me. :)
Elastic Pitch trouble and double menu GS-DK Pro Tools TDM Systems (Mac) 8 02-17-2009 05:44 PM
Protools 8 Menu Problem colinweeks Pro Tools TDM Systems (Mac) 4 01-06-2009 01:50 PM
How do I get a plugin,menu and user guide for Protools le Sean L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-19-2008 11:18 AM
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! a2zproductions Pro Tools TDM Systems (Mac) 16 05-08-2008 08:30 AM
putting ProTools into startup menu peterfitz Pro Tools TDM Systems (Mac) 3 11-03-1999 11:44 AM
