Old 01-02-2014, 01:26 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Is the Clip Gain the same as a Trim Plugin?
Was wondering if it was easier and sound wise better to use Clip Gain than the trim plugin? Trying out static mix if that's what everyone calls it. Where you put every fader to unity and get it close, then start adding your plugs etc.. Just wondering if there was any + and - to using either one or are they the same thing?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
[email protected]
Live and Let Live
Old 01-02-2014, 02:44 PM
Craig F Craig F is offline
Default Re: Is the Clip Gain the same as a Trim Plugin?
Clip Gain is between the disk drive and the first insert slot so you not eating up a slot.
Thank you,
Craig
Old 01-02-2014, 02:46 PM
Aaaaaaaaaaa😳
You very wise. Me learn. Thumps chest😜
[email protected]
Live and Let Live
Old 01-02-2014, 02:59 PM
The Weed's Avatar
The Weed The Weed is offline
As far as I can tell Clip Gain is like real time, automatable AudioSuite Gain. And it's Pre Fader.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-02-2014, 04:39 PM
PMF Media PMF Media is offline
Correct, clip gain is pre fader- the first step in the process, so whatever you do in clip gain will effect everything else "down stream" (EQ, Dynamics, Sends etc.) also, the CG is non-destructive and can be altered at any time, Audiosuite will create a new file and rep[lace the existing original - probably not quite as flexible, depending on your situation.
Old 01-02-2014, 07:06 PM
And the Trim Plugin?
[email protected]
Live and Let Live
Old 01-02-2014, 07:45 PM
in any of the 10 slots you like
Thank you,
Craig
Old 01-02-2014, 10:13 PM
The Weed's Avatar
As long as you put the Trim plug-in before any other plug-ins on the track any volume automation done with the Trim plug-in will happen before the other plug-ins, ie pre fader, unlike regular volume automation.
Cheers,
SonoBus
Old 01-02-2014, 10:51 PM
bashville bashville is offline
The cool thing about clip gain is you're riding before all of your processing, so you can hit your compression and what not with a more equal level.
The bad thing about clip gain is you're riding before all of your processing, so if you're clamping down a lot with a compressor, you might not hear a ride as much as if you did it afterwards.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 01-03-2014, 12:25 AM
JFreak's Avatar
JFreak JFreak is offline
Clip Gain is pre-HEAT which I think is most important.
Janne
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Gain plugin bug? Writes distortion to start of first processed clip iain_m Pro Tools 10 18 06-03-2013 03:41 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
Clip Gain doesn't follow trim edits bug? JR Fountain Post - Surround - Video 0 02-17-2012 06:28 AM
Is it better to use a Trim plugin or Gain plugin? SpinningDisk Tips & Tricks 5 01-19-2010 02:43 PM
