  #21
Old 01-02-2014, 04:04 AM
Audioartist Audioartist is offline
Default Re: Help us help you
Originally Posted by DanielEUCON View Post
@MichaelK - is you system boot drive an SSD by chance?
@DanielEUCON If I want a 100% crashsafe PT/eucon system, is it a bad idea to use a SSD boot drive?
Have you seen any signs of more problems with systems with SSD boot drives?
  #22
Old 01-02-2014, 04:18 AM
Neale Eckstein's Avatar
Neale Eckstein Neale Eckstein is offline
Please explain further about the SSD drive. I'm enjoying the speed. Is this a protools issue or an artist series issue? Is there evidence that a Pro Tools 10 co-install reduces stability because at this point, I'm not using it.
  #23
Old 01-02-2014, 05:52 AM
Southsidemusic's Avatar
I doubt that SSD drives are the problem as we have used SSD's since they came out and costed more that a used car with no issues at all so there has to be something else going in if you still have problems with EuCon 3.1
Happy New Year Guys and Gals
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #24
Old 01-08-2014, 07:45 AM
MichaelK MichaelK is offline
The only problem with 3.1 is that the display is STILL badly delayed when banking. It's not a little "bug," it's a serious problem! I hope it's still being addressed... is it?
-- Michael
PT Ultimate Native 2021.10
Mac Pro 7,1 16-core, 288G RAM
OS 11.6.1 Big Sur
  #25
Old 01-15-2014, 04:14 AM
Jabu Jabu is offline
Hi
I had a problem with my ethernet port and so I bought an apple adapter (ethernet to thunderbolt), I would like to find out whether it will work properly and how do I setup my artist mix (mixer) to link with my FCP 7 when I want to work, been having this problem since last year.
Best
Jabu
  #26
Old 01-15-2014, 10:42 PM
ALSTUDIOS ALSTUDIOS is offline
Hi
Issue confirmed - even more serious. If you do several fast changes in banking, sometimes the communication shut down.
Something new with surprises
Cheers
ALSTUDIOS REGENSDORF SWITZERLAND
[email protected]
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win11 64Bit, Cubase Pro 12.0.52
  #27
Old 02-27-2014, 10:02 PM
Well...
Since updating to EuControl 3.1 AND deleting prefs for EuControl & PT after updating...
...for the past month or more the Artist Mix screen has not frozen once. Victory!!
I've recently started letting EuControl load automatically at startup. Everything works great as long as the Artist Mix is powered up before the OS loads. But now, if I add the surface after startup is done, it will not work in Pro Tools. Pro Tools doesn't see it unless I restart the computer and it's recognized at startup. Oh well. Beats a frozen screen any day!
-- Michael
OS 11.6.1 Big Sur
  #28
Old 03-20-2014, 03:32 PM
Tobyboyce Tobyboyce is offline
I am running Logic Pro 9.1.8 with OSX 10.9.2 I am having issues with my Eucontrol and Artist Control connecting. After a boot it connects for about 60 seconds and them looses connectivity. I also have two Artist Mix that have no trouble staying connected. Any suggestions for a fix.
  #29
Old 03-31-2014, 09:19 AM
priorytools priorytools is online now
Originally Posted by JC Haydon View Post
If you haven't reached out to me personally, you should.
[email protected]
Hi JC.
I'm "reaching out" . .
Long story with the S6, so have some artist mixes to "work" with . Trouble is, they don't work very well. .
PT11 HD New macpro .
When will there be an update date that gets rid of the huge delay i updating the little ocd screens on the mix units ?
Much to do .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
  #30
Old 04-01-2014, 09:03 AM
OK... after using EuControl 3.1.2 with Artist Mix several weeks...
The frozen display is back with ver. 3.1.2. Ver 3.1 didn't seem to have a problem at all.
It happens about as often as it used to with ver. 3.0. BUT the good news is that it snaps to the correct display instantly when I move the mouse. Not even clicking it, just moving the cursor.
Maybe that was always possible, but if so I'd never noticed it before. I hope that helps.
P.S. - just to be clear... finding a quicker solution is better than before, for sure. But better still is when it just works right! I'm going to re-install 3.1
-- Michael
OS 11.6.1 Big Sur
