Old 04-10-2011, 04:01 AM
AndersDM AndersDM is offline
Default Upgraded to PT 9, Eleven Rack Expansion pack disappeared!
I just upgraded to PT9 on my system that already had the Eleven Rack expansion pack installed. But after the upgrade, the expansion pack amps and effects dissapeared from the eleven rack interface in PT.
As you can see in this screenshot the white boost is selected and but there is no graphics in the edit window and the effects chain has a weird icon... The amps and cabs from the expansion pack is not even in the list and can't be selected from the PT GUI. Selecting them from the hardware panel works as normal.
Anyone have any idea what's happening here? I have tried running the eleven rack firmware update again after installing PT9, but it didn't make any difference.
Any help on this would be much appreciated!
Thanks!
Anders
Old 04-11-2011, 09:56 AM
miketeachesclass miketeachesclass is offline
Default Re: Upgraded to PT 9, Eleven Rack Expansion pack disappeared!
I had the same issue. Just re-run the EXRP installer. That took care of it on my end.
Old 04-11-2011, 10:35 AM
Resonant Alien Resonant Alien is offline
Yes, you have to load ERXP after PT install. The ERXP is an adder to PT9 - the base PT9 code does not (yet) include the additional GUI elements for the exp pack. I would assume that in a 9.0.3 or 9.0.4 spin of PT9, they will incorporate this so that running the ERXP installer will no longer be necessary....
Old 04-13-2011, 01:18 PM
Thanks guys, that did the trick!
I forgot about the ERXP installer. I only tried reinstalling the firmware update...
Old 06-17-2011, 11:03 AM
brianiac5150 brianiac5150 is offline
I had this same issue a few minutes ago, re-installed the ERXP, which fixed the icon issue, but now when I attempt to switch between amps in the AMP TYPE drop down box it's very slow to switch to the new amp or won't switch at all, but the sound changes.
I also tried switching FX, but didn't seem to have any apparent lag.
Any help would be greatly appreciated.
THoM Facebook
Old 06-17-2011, 12:36 PM
Ran PT9.0.3 updater in repair mode and it seems to have fixed it. We'll see...
THoM Facebook
Eleven Rack Expansion Pack and PT 10 dckerley Windows 6 12-14-2012 01:16 PM
will there be a new expansion pack for eleven rack? dbvoyager Eleven Rack 19 06-05-2012 07:32 PM
Eleven Rack Expansion Pack Legion6789 Eleven Rack 6 01-10-2012 10:23 AM
Eleven Rack Expansion Pack Hank Marvin Eleven Rack 16 08-31-2011 06:12 PM
Eleven rack expansion pack reycantong Eleven Rack 11 01-25-2011 01:31 PM
