Old 05-04-2010, 03:56 PM
aliaspail aliaspail is offline
Default HOW TO: Skip over measures?
is there a way in protools to skip over some measures during playback, rather then deleting or removing time?
i basically want to see what it sounds like to skip over a section, without having to delete the section.
what's the terminology and process for this? i can't find this?
basically, i want to select section of a protools session. have the playback start a bit before this selection, when it gets to the selection, skip it, and play the section after the highlight.
a numbered step by step would be great, or link to instructions.
sincerely,
b
Old 05-04-2010, 04:10 PM
mindnoise mindnoise is offline
Default Re: HOW TO: Skip over measures?
I am not exactly sure what you mean,
but it sound that Playlist are for you.
Check you PT Reference Guide p.527
or Memory Locations and Markers p.705
and Arranging Regions p.715
last: PT11.3.1
Old 05-04-2010, 06:31 PM
AfterJohn AfterJohn is offline
You can mute the regions (CMND + M) but that doesn't skip them. You could duplicate all the playlists (OPTION Select) and then delete the measures you want gone and flip between the playlists.
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2
redtuxedo.com
milkmoneyconsulting.com
mindexpansiontechnology.com
Old 05-04-2010, 06:53 PM
flommer flommer is offline
Do a quick "save as" Session Name v2, and then mangle it to your heart's desire. You can always go back to Session Name if you don't like the results. Just don't do any permanent editing of any audio files (audiosuite, etc)..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 05-05-2010, 10:30 AM
SKI's Avatar
SKI SKI is offline
I'm not going to even try to see a functional purpose in wanting to do that however I will give you a solution that will work.
-Make sure you are in Shuffle Mode
-Highlight the region and make sure all tracks are highlighted
-Do a Cut on the Region.
-Play the song
-Use the Redo Function to put the Region back
If it's really something you need to do that will do it.
URBAN MUSIC-
(Hip Hop and R&B)
Old 05-05-2010, 03:01 PM
Mothlight Mothlight is offline
This is a question only a Logic user would ask. In logic, if you draw a loop from right to left instead of left to right, logic will skip over the highlighted section during playback.
this should shed some light on the question, however i dont have an answer for you.
Old 05-06-2010, 12:16 AM
SKI's Avatar
SKI SKI is offline
If you go back to the Digi DVDs they use to promote with, you will see them highlight and cut to listen without a section and that was probably 7 to 8 years ago.
Never was something big on the feature request list and may never be.
I guess they feel highlight and remove, click to put back if you want to listen without a section is good enough.
**Hope this doesn't double post**
URBAN MUSIC-
(Hip Hop and R&B)
Old 12-11-2017, 10:52 AM
ayskura ayskura is offline
Yes this is really from Logic Background which is really great to quickly preview a part of a song without any editing. Also you guys make it seem very easy but in fact it isn't as sometimes (as in my case) you have tempo maps, odd signatures and more things happening like automations and trim and this is not something you want to test in the session page before being sure it sounds good... I really wonder why some simple things are so complicated in pro tools and especially why hardcore pro tools fan always deem these request as unnecessary... I think there should be some way to skip between markers during playback no?
Old 12-11-2017, 03:31 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Logic started as a midi sequencer and it is still its greatest strength. Pro Tools started as a digital sound recording software and became the defacto "Audio Recording" for professional use. Which is a long way of saying-though you can use it for creating songs from midi/instruments from scratch, technically it was designed to be used to record live instruments and has been updated to add post production, midi, etc. Which is why many Pro Tools users also use Logic. They complement each others strengths-do pre production in Logic is my suggestion.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 12-12-2017, 02:33 PM
Studio One also offers this(IIRC) and it would be nice if PT allowed for it as it makes for fast auditioning of arrangement changes(and the suggestion has been sent to developers at Avid). Maybe in the future For now, Shuffle mode is your friend(with the ALL group enabled) and Save As... so your original version doesn't get hopelessly mangled
Skip invalid fades..... andyselby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-12-2012 04:09 PM
Why does playback skip in PT? Shatzer Pro Tools M-Powered (Win) 2 02-04-2010 07:07 AM
Bad Sectors - skip over them? EGS Storage Subsystems 3 10-06-2007 07:27 PM
skip all fades? tomcat Tips & Tricks 9 11-17-2001 12:02 AM
Skip all button surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2001 07:07 AM
