Old 02-06-2010, 10:03 AM
kingof6strings kingof6strings is offline
Default Input Gain Adjusting
Hi there, does anyone know if there is a way to adjust the input gain on a channel within pro tools 8 le, without having to adjust the output from my eleven rack interface? Every demo I have seen always uses some form of hardware mixer within input gain knobs on it.
thanks
Old 02-08-2010, 05:23 AM
1ace1 1ace1 is offline
Default Re: Input Gain Adjusting
Input gain can only be adjusted external to the computer, so no.
A:)
I Love Audio!!!
Old 02-08-2010, 07:42 PM
albee1952 albee1952 is online now
Back to the OP, what are you trying to make happen? If you are concerned about a dry track being very low, don't be. That is the correct level and will work correctly for re-amping.
Old 02-09-2010, 04:01 AM
ok thanks, sorry i'm new to pro tools what exactly is re-amping? do you have have to run some sort of signal boosting plug-in?
Old 02-09-2010, 05:58 AM
Re-amping is simply sending a guitar track out to an amp(real or amp-sim) to change the sound. Eleven rack allows you to record your processed guitar sound AND a dry(un-processed guitar signal) to another track so you can re-amp it later if you decide you want a different tone. Check it out in the manual and the online videos as its a very cool feature. You can do re-amping with most any system, but Eleven rack makes it really simple(as simple as this stuff gets...).
Old 02-09-2010, 06:10 AM
my issue is that I have a fairly low output from my microphone - it is phantom powered going into my eleven rack for recording into pro tools but signal is weak, I only get a decent signal when the gain knob is pretty much all the way up on the eleven rack. I there another output signal adjuster somewhere?
Old 02-09-2010, 06:42 AM
The only other place there would be in your set-up as described is on the mic.
What model is the mic? Does it have a pad switch (attenuator) and if it does is it on?
If it does and it is turn it off.
A:)
I Love Audio!!!
Adjusting Gain for 2nd Stage pmueller VENUE Live Sound Systems 4 07-09-2013 03:51 AM
192 adjusting input and output gain Raoul23 Pro Tools TDM Systems (Win) 3 09-28-2010 07:34 AM
adjusting gain deerwomon Digidesign Hardware & Software 2 08-07-2002 07:24 AM
Adjusting input levels ch.3-8 dummy20707 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-29-2001 08:32 AM
Adjusting Gain Levels/ Headphones pmh3r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-20-2001 03:42 PM
