Old 08-08-2006, 02:17 PM
Bassturbator Bassturbator is offline
Default Change/Toggle Keyboard Focus?
Is there a way (keyboard shotcut eg.) to toggle between the keyboard focus, besides clicking on the icon?
(you know the a...z icon)
This would be verrrrrrry handy
Old 08-08-2006, 07:54 PM
Default Re: Change/Toggle Keyboard Focus?
Bassturbator
Hold Control Key and perform your Key Command.
filosofem
Aaron Mulqueen - 001 HD Native
Old 08-08-2006, 09:25 PM
Shawn Simpson Shawn Simpson is offline
If you're talking about a way to switch the edit window command focus then you can hold down command+option, then press 1, 2, or 3 on the qwerty numbers to switch between edit focus, regions focus, and groups focus.
Old 08-09-2006, 03:56 PM
Aaaaaaah thank you very much!!
Will try that asap!
Cheerz dude!
Old 08-18-2006, 01:51 AM
MikeTrahearn MikeTrahearn is offline
Hi Guys,
Just what I also needed to know since I converted my keyboard with the Editor's keys sticky labels.
However, I find that The Command+Option+1,2,3 doesn't quite do what I'd expect...
I thought that Command+Option+1 would toggle the edit focus, whilst 2 and 3 would toggle the regions and groups respectively. But the operation doesn't seem that simple - the groups a..z stays lit but only becomes active on the keyboard if i have the mix window at the front. Sometimes the edit focus goes off when I didn't realise I'd done that.
Could you kindly explain how this feature is supposed to work? I'd love to get to do things much quicker and command focus is definitely the way.
Thanks very much,
Mike
Qualified Pro Tools HD7 Operator
Old 01-30-2018, 09:52 PM
RicoRoss's Avatar
RicoRoss RicoRoss is offline
Command/Option 1, 2 or 3 only works when your focus is already IN the edit window.
Are you asking about the keyboard command to toggle between edit and mix windows?
Command/+ toggles between mix and edit windows.
Control/+ toggles you to and from the MIDI editor window.
Hope this works for you.
13" Retina MacBook Pro, macOS Big Sur 11.6
Pro Tools 2021.12
Apogee Ensemble Thunderbolt 2
RME Octamic II
UAD Octo Satellite
PT9 Keyboard Focus hwill2008 macOS 4 11-30-2011 11:54 AM
Help with Keyboard Focus on PT 8 Consuption 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-10-2009 12:56 PM
C 24, Waves, Keyboard Focus Rainer Heesch ICON & C|24 1 01-13-2009 01:47 PM
A Keyboard Focus Q innesireinar Pro Tools TDM Systems (Mac) 0 11-13-2007 09:29 AM
question: command focus toggle c-post Tips & Tricks 2 08-21-2001 03:12 PM
