Audio Device Buffer Underflow \"error 6088\"
I need HELP!
i just bought Pro Tools le 7.0 002 rack. It is running on a Dual Processor 2.2 GHZ Compaq XEON with 2 Gig of RAM on the Windows XP platform. After loading Pro tools le 7.0 on my pc and opening a demo session that came with the software, in order to test the unit and software... as the demo session is playing suddenly i end up with an error " The device Buffer Underflowed. If this occurs frequently try decreasing the H/W Buffer size in the playback engine. etc... i have changed the settings within the playback buffer but nothing seems to help and this problem continously happens... I have not been able to play out the entire demo session. Does anyone have a clue how to STOP this from happening. thanks... |
Re: Audio Device Buffer Underflow \"error 6088\"
As I mentioned in your other post:
I had the same problem, so I went through each device in Device manager, disabling it , and found to my surprise, it was my scanner causing the problem. Everything worked fine once I disabled it.
If you disable each device, one by one, you may find a similar thing.. Cheers Jason |
Audio buffer underflow -6085 error on mac pro | paul mccarthy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 30 | 02-21-2011 10:25 AM |
audio device buffer underflow error please help | idleave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-05-2007 07:51 AM |
H/W Buffer Underflow error-6088 | audio[LAB] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-15-2006 08:20 PM |
audio device buffer underflow error 6088 | Destinee-One | Pro Tools TDM Systems (Win) | 1 | 04-16-2006 09:39 AM |
Problem with Audio Device Buffer Underflow . | RobJV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-10-2005 06:15 AM |
