Logging DATs...
Looking for some opinions here -
Have a client with 200 DATs, each has at most 60 minutes of audio. Would like the DAT audio to be converted to .wavs, named, and placed on a hard drive so he can access the files. My thought is to load the DATs into PT, and export the regions as audio files, then rename accordingly. The cost to my client, even with a serious discount, is going to be HUGE. I'm looking for a standalone alternative, assuming one exists. Thanks in advance, y'all.
"I don't feel tardy." - DLR |
Re: Logging DATs...
Hi there,
if you rent 3 more dat machines, you record 4 tapes at once (4 hours of audio in 1 hour studio time). I know, that in our public national radio there is Pyramix system used for such tasks. You can have several projects open at once, and you can inpependly use all functions, controlls, trasnport and so on... This is not a standalone solution but might help... Regards Kuba |
Re: Logging DATs...
If you have a PC, there are programs that analyze the incoming bitstream from a DAT and automaticallly break up the recording according to PNO. It's information that's transmitted down Spdif lines in the bits between 17 and 24. Somehow, I don't think AES carries this info. You can read about the technology here: http://www.rme-audio.com/english/techinfo/tms.htm So, you could set one DAT at a time to record, and just batch export the files when it's played through. Not too bad! Hope this helps, Stuart
IMDB |
Re: Logging DATs...
Two ideas:
1) A stand-alone compact flash recorder. I recently did a large transfer project for which I purchased an M-Audio MicroTrack 24/96, which has a SPDIF input. I ran several 2GB cards, swapping them out periodically. I babysat the transfers, and didn't have to tie up a computer. This worked great, though track/index markers were not an issue for that project. It'd be worth looking into whether some of the units on the market will break tracks via track ID over spdif. 2) CD-Recorder. If your DATs are at 44.1 and not over 80 minutes in length, you could use a stand-alone CD recorder set to glean the track IDs from SPDIF. Then rip the CDs to WAV. Some CD-R decks offer sample rate conversion, but you'd have to decide whether to take the quality hit if you're in 48k. -jeremiah |
Re: Logging DATs...
You might want to contact Gallery Software in London. They used to make a product that would load Dats faster than realtime and would break up the tapes by ID. He does not make it anymore, the transport he used stop being manufactured. But he might be able to let you know who in your area bought one that you could rent. As I recall the machine loaded the dats at 2-4 times normal speed.
Dave P
Dave Paterson |
Re: Logging DATs...
why not use four machines or more. connect them AES/EBU to your 192 i/0. record all for machines at the same time. so in PT you have your four stereo tracks running. you are only limited by the number of machines and AES/EBU inputs and DAT machines you own.
23.98 EDL/30fps Production DATs | jahhn | Post - Surround - Video | 1 | 07-11-2005 07:36 AM |
portable DATs anyone? | chagos | General Discussion | 5 | 03-04-2004 10:27 PM |
Sony Timecode DATs | fakshen | General Discussion | 1 | 07-11-2003 03:15 AM |
How do you guys dump your DATs into PT? | ROOM 12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-28-2001 12:32 AM |
Dats or DVD? | mpro | Storage Subsystems | 12 | 05-26-1999 04:37 PM |
