Old 06-24-2022, 09:50 AM
CHRIS AIKEN CHRIS AIKEN is offline
Default Db25 Inputs / Line
I was wondering if the db25 inputs (switching to “line”, no external preamps) is the same quality as using the xlr inputs and having it set to “mic”.
It’s more convenient for me cable wise but I want to make sure there’s no difference in quality.
Thanks!
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate
Old 06-24-2022, 09:55 AM
Default Re: Db25 Inputs / Line
Line the same as Mic. No.
Line in the same as DB25 line in. Yes.
Look in the manual, page 42-43. Specifications cover both DB25 and TRS as the same thing.
Line "True Bypass" (also available on both DB25 and TRS) gives you 1dB better SNR and 1dB better dynamic range. Good luck with hearing that.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 06-24-2022, 04:28 PM
Dominic
Interesting, I’m used to no gain boost on line ins. On the db25 connectors they give the same amount of adjustable gain as the “mic” setting. (50db I think).
That’s why I asked, it seems to function the same as using the mic setting.
Old 06-27-2022, 10:55 AM
musiczebra79 musiczebra79 is offline
Did some drum recording the other coming in to the line inputs of the carbon from my console, sounded great
Old 06-29-2022, 08:43 AM
K Roche's Avatar
K Roche K Roche is online now
Well they both spec 60 db But I am a bit confused are you asking if Line in via the combi connectors is going to be noticeably better than with the DB 25 connections ?... I am thinking the quality would be the more or less same
I use the DB25's for my external HW effects ( a stereo reverb and a 2 channel compressor). BUT I have those DB 25 channels set to +4 and "True Bypass" and set the gain on the HW units themselves
System :
Enjoy the Journey
.... Kev...
Old 06-30-2022, 04:27 AM
Thanks for the reply. I was wondering if using the db25 connectors with a mic plugged in directly (no external preamp) would be the same sound quality as using the combi jacks set to mic.
I tried it finally the other day and it works but isn’t the same quality.
Old 06-30-2022, 07:58 AM
K Roche's Avatar
Interesting never tried anything like that .
Question
#1 How does one plug a mic directly into a DB 25 ?
System :
Enjoy the Journey
.... Kev...
Old 06-30-2022, 08:22 AM
Using a dedicated line in for microphone input is not advisable. Setting aside the lack of phantom power, they are designed to take entirely different signal levels and often have rather different impedances. It's no surprise it didn't sound good.
Dominic
Old 06-30-2022, 05:34 PM
Question
I have a db25 to xlr snake.
Old 07-08-2022, 08:09 PM
Bookerv12 Bookerv12 is offline
Uuuugh?....
Lots of basic signal flow/routing/levels misunderstanding in this thread....
bookerv12
FS: Avid DigiSnake 12 ft. DB25 to DB25 Cable (9940-29651-00) TVPostSound Buy & Sell 0 03-27-2017 12:14 PM
DB25 Male to DB25 Female Ext. Cable Barry Johns Pro Tools HDX & HD Native Systems (Mac) 11 06-12-2016 11:30 AM
How do I utilize the Line inputs when all my XLR inputs are being used? 007audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2009 08:21 PM
Mic/Line and Line inputs on Mbox2 Pro DAT11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-16-2007 08:06 PM
Control 24 Pin Out For DB25 "Line Out" Kevin101 ICON & C|24 2 01-31-2003 09:56 AM
