System 9.1 & 9.2.2 corrupts digisetup
I upgraded from 9.0.2 to 9.1, then to 9.2.2.Now,when I launch Pro Tools,
I get a "Hardware is not available, or is in use by another application" message. I can throw out the digisetup preference file, and reboot, but then I lose my preferences, and have to setup again. I have purged every unneccessary extension. Any ideas? |
Re: System 9.1 & 9.2.2 corrupts digisetup
Go to your sound control panel and make sure the input and output are not set to Digidesign H/W.
You mean that it shouldn't be set for digi H/W, even if i'm using it?
If the finder is using the Digi H/W for alert sounds or anything else, that hardware will not be available for Pro Tools. You can use the Digi H/W anytime you don't have PT running, but you need to set your sound control panel to 'Built-in' before you start PT. Good luck.
Digisetup.OSX file Becoming Corrupt | Chief Technician | Pro Tools TDM Systems (Mac) | 13 | 11-17-2008 07:42 PM |
EZquest won't mount & dir. corrupts! (OSX 10.3.9) | crispuk | Storage Subsystems | 0 | 07-27-2005 12:55 PM |
digisetup.osx | Ronbfp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-13-2004 01:40 AM |
Digisetup, DAE Prefs Folder and Pro Tools LE 5.0 p | audiotracker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-13-2003 03:42 PM |
Internal sound disappearing due to DigiSetup/ASLM extensions? | soundispatch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-20-2003 06:56 PM |
