Old 04-03-2019, 12:57 AM
oossyy oossyy is offline
Default Reverb won't record
I been trying to print a song in pro tools by using a print track. Everything records fine on the print track, except for the reverb on the vocals. I have inserted the reverb on a vocal bus as you can see on the picture. Any tips on why the reverb is not recording on the print track??
Old 04-03-2019, 01:41 AM
BScout BScout is offline
Default Re: Reverb won't record
Easy.
Because you are sending your Reverb channel's output to your monitor track and not your print bus. You've done the same with your Delay track (if you were using it.)
Frankly, looking at your routing, I don't know why you are sending your submix via a Send to your print bus. It should be sent through the output of the submix track to your print bus.
Right now you are double monitoring your signal: once from the Submix track and once from the Print Bus track. Another mistake.
Pro Tools Ult 2019.5, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-04-2019, 01:32 AM
JFreak's Avatar
JFreak JFreak is online now
Yea, the submix buss is totally unnecessary. Just use the print (audio) track for printing and monitoring. Just remember to have either track record armed or input monitoring enabled, otherwise you are always monitoring the printed audio track.
Janne
Horrible Delay and Reverb on "record enabled" in PTLE 8.0 jbandhisguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2009 10:32 AM
Record Mode Shuts Off and no Reverb KennyH Pro Tools M-Powered (Win) 2 02-11-2007 09:45 AM
Q: Record and monitor reverb w/ MBOX?? RAustin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-16-2002 07:39 PM
Reverb on record enabled tracks jaceever Tips & Tricks 2 07-25-2002 01:22 PM
About to sell PCM91 in favuor of Ren Reverb-Reverb One - is this a mistake? hokuspocus Pro Tools TDM Systems (Mac) 14 04-15-2002 02:07 PM
