Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 03-06-2016, 08:42 AM
frcjt frcjt is offline
Default config mic for stereo input for ft c600
how can i connect a mic to the Fast Track C600 and record as a stereo signal?
Old 03-06-2016, 09:26 AM
Default Re: config mic for stereo input for ft c600
i have a stereo input signal when not in pro tools, but cannot get a stereo signal when trying to record in pro tools!
i am missing something
Old 03-06-2016, 10:31 AM
Most microphones are mono, you cannot record a stereo signal directly from those microphones.
What exactly are you trying to record? And with what make/model microphone?
It is impossible to guess what you are trying to do or how much experience you have. Many questions like this reflect a misunderstanding of how most "stereo recordings" are made.... with mostly mono sources panned into a stereo soundfield at mix time.
If you are trying to record true stereo, say with an XY mic pair recording in a live space like a choir or live drum set then yes you are going to then record to a stereo track, otherwise you should be working with a mono track in Pro Tools and just panning that into a stereo output/bus.
Old 03-16-2016, 06:38 AM
got it! thanks!!!
Odd Input Identifiers: Avid C600 / ProTools 9.0.6 KineticSound FireWire & USB Audio Interfaces (Mac) 3 09-03-2013 05:27 PM
New C600 and Input Monitoring manfromspace macOS 2 11-04-2011 10:33 AM
Mbox/Pro Tools LE issue with SampleTank input device config steve_canuck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-18-2008 04:46 PM
Config For 003 question 1 - Input Gain. drumnow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-05-2007 08:42 PM
How do I get a mic as stereo? it only has 1 input PROPhr34k Tips & Tricks 10 12-16-2003 11:07 AM
