Save Copy In for "updating" a backup folder?
because of memory reasons I have the idea, to work from a external disk. For backup I would say each time after finishing a important step "save copy in" and would choose my internal SSD. Can I tell PT12.5 to "update" this internal backup folder? Otherwise I guess it would always copy all audio objects again and again and again. |
Re: Save Copy In for "updating" a backup folder?
any idea but not sure if it would work .. would be to use Carbon Copy Cloner to Increment the Audio Files folder, Backup files Folder, but woth the Session File, you would have to Replace it .. the Waveform Cache also needs to be updated .. you could test it if you have CCC .. if you do not i could try it later and see if it works .. like i said it is a good idea .. would keep backup lean and clean .. cheers john
I use both CCC and Free File Sync (https://www.freefilesync.org). One of the nice things about CCC is the Safety Net feature and it's great for cloning system drives. Free File Sync is free and very capable. Just make sure you're always syncing in the right direction. FFS is also cross-platform. If PC, I use Microsoft's Sync Toy (free download).
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Just use Synchronize Pro X.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
I know CCC, must look if it's still on my disk.
FreeFilesSync is also here - but I cannot work with it - that's what you said: you must be sure and check what you're doing, each time. Okay, this is with every backup system But I had to rename main folders after they decided to count them. The PT sessions were in a sub sub folder. Now, FreeFilesSync is not able to handle that. I tried every three options I could find (size, name and so on). So it warned me, that if I am sure, if the folder I wanna sync is reallyreally the right one (yes!). That's the human factor. And I (try to) use only software which fits to that. No the way around |
"Save plugin settings to session folder"...and repeat? [solved] | Ticker | Pro Tools 12 | 3 | 07-12-2021 08:10 PM |
PT10 : Volume automation disabled after "Save copy In" | brenny | Pro Tools 10 | 2 | 06-18-2015 02:33 AM |
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." | Elias Stiza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2012 07:06 PM |
"Save copy in..." function copies files that have been cleared from session. | ragbor | Pro Tools TDM Systems (Mac) | 7 | 02-08-2010 12:25 PM |
"Save Session Copy" MUST copy AIIFF files??? | BHeller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-11-2001 12:33 AM |
