Old 05-26-2005, 11:56 AM
Erik Sojdelius Erik Sojdelius is offline
Default Tiger install: Clean or update?
Did you guys do a clean install or did you just update your system?
I'm going from 10.3.8, any suggestions?
TIA,
Erik
Old 05-26-2005, 12:54 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: Tiger install: Clean or update?
I just updated. No problem. i would back up first though.
NOTE: watch out if you have the DotMac Virex 7.5 installed. It has a process that will grab 99%of your processor. You have to uninstall it with the installer disk image and use 7.2 if you want. Also you will want to give it an hour or so for Spotlight to index your drives before you try to do anything intensive.
hth,
jim
noise | jimlongo
Old 05-26-2005, 01:12 PM
emf1138 emf1138 is offline
IMO, it's always best to do a clean install. ESPECIALLY with PT.
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 05-26-2005, 01:38 PM
Vaphoron Vaphoron is offline
If you are in a hurry just update to Tiger but I would have to agree that clean install is always nice if you have the time and energy. I like to be forced to clean up the system and backup files too so I enjoy reinstalling the OS.
- Jason
Old 05-26-2005, 01:52 PM
MARVINBASS's Avatar
MARVINBASS MARVINBASS is offline
TIA,
Erik
I did an update. If you have alot of virtual instruments, this is the best way to do it.
My System is:
Mac Pro 3.2GHz 6 Core
32GB RAM
1- HDX
1 - Apogee Symphony Mk2 8x8
1 - HD 16x16 Interface
MOTU MTP/AV
Second System
Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2
32GB RAM
1 - HDX
1 - Avid Thunderbolt 3 Expansion Chassis
1 - HD 8X8 Interface
MARVINBASS Digital Audio, LLC
Ex PT Beta Tester
Woodland Hills, CA.
Old 05-30-2005, 10:00 PM
Slideman Slideman is offline
A guy at the Apple Store told me to update the OS (and everything else) to 10.3.9 before updating to Tiger. Said it would be smoother doing that than updating from 10.3.8 or older. Any thoughts?
The only real question I have about Tiger is the Spotlight issue. If it indexes files as we're recording, will that slow things down? I know there's a "Privacy" section of Spotlight to turn off root folder indexing but do we have to tell it to ignore audio drives everytime we hook up a previously unmounted drive? Or is this whole thing a non-issue?
Thanks.
HD3 accel PT 6.9.2
OSX 10.4.1
G5 dual 2.0
3gig ram
Old 05-31-2005, 08:28 AM
mike connelly mike connelly is offline
"If it indexes files as we're recording, will that slow things down?"
It should only index files once when Tiger is first installed, after that it indexes files as they are saved so recording shouldn't be effected. If you connect a removable hard drive, it will index it, you can tell it to ignore that drive, if it's always the same drive it should remember which drives/folders not to index.
Old 05-31-2005, 09:46 AM
Makes sense, Mike. Thanks.
HD3 accel PT 6.9.2
OSX 10.4.1
G5 dual 2.0
3gig ram
Leopard to snow leopard clean or update install joji Pro Tools TDM Systems (Mac) 10 01-01-2011 02:21 PM
Clean install, which update is best for XP cananball 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-31-2010 07:16 AM
10.4.8 (Tiger) Security Update 2009-005 (Tiger Intel) Help Brushfire Pro Tools TDM Systems (Mac) 1 11-25-2009 09:16 PM
Clean install of 6.9.2 on a Mac Mini (Tiger) John G Collins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-11-2005 02:27 AM
proper panther to tiger with clean tiger install doug_hti Pro Tools TDM Systems (Mac) 21 07-10-2005 05:00 PM
