Hey all - Any help on this would be appreciated, as I can't get a clear answer from Avid.
I purchased and used an M-Audio Firewire 410 and ProTools M-Powered 7 some years ago. Since then I have upgraded my Mac OS to 10.8.5, and it appears that I cannot continue to use PT M-Powered 7 on this OS version (or not that I can see). I'm trying to determine what is the best solution for me to get Pro Tools up and running on this system. I'm wondering which of these scenarios will work ... 1 - Is there a way (work-around) to make PT M-Powered 7.4.2 AND the Firewire 410 work with my current OS? (ideal) 2 - Is there a way to upgrade my version of ProTools to a version that is compatible with OS 10.8.5? If so, will my old iLok that I purchased with PTMP7 work? Will my Firewire 410 be compatible with a new version of PT? 3 - Do I need to scrap the PT and interface that I purchased and get a new version of PT and a new interface? Obviously, scenario 1 is ideal, but if it is not an option, than I am trying to determine if scenario 2 or 3 make more sense. I've really struggled to find answers on the AVID site, forums, etc. Any advice is thoroughly appreciated. Thanks! |
I would give up entirely on Pro Tools 7 anything on recent OS X releases.
You can buy a crossgrade from Pro Tools MP to Pro Tools 11 on the Avid online store or any retailer. List price is $399. I am not sure about whether the 410 practically works on any current OS X version, no current OS X version is officially supported, and I'd hold out no hope of any updates from M-Audio or Avid to ever address issues if there are any. You could at least test if you can get it to work with say Garage band now. Or you can buy an Mbox Pro or Eleven Rack with a bundled full pro Tools 11 license. The Eleven Rack is especially a bargain if you work with Guitar or bass. Or buy any third party CoreAudio compatible interface and use your upgraded Pro Tools 11 with it. |
Thanks. As a casual recorder (demos with guitar, bass, piano, vox), I'm exploring how to keep costs down while having basic recording/mixing capabilities.
If the crossgrade is $399, then I might be better off purchasing a new basic interface such as the Fasttrack Duo or Mbox. That way I know they will work with the bundled PT (even if it's only PT Express) and I can avoid potential compatibility issues with the Firewire 410. I was just hoping that I'd come across an elegant solution to allow me to use what I have, but that's looking less likely the more I research it. Appreciate the info and suggestions! |
![]() Quote:
A Mbox Pro with Pro Tools 11 by comparison costs you around $1k. The Mbox (non Pro) is a lot cheaper but includes Pro Tools Express (based on Pro Tools 10 technology and has limited features) not the full Pro Tools product. Its a good low cost option but check carefully on the software and IO limitations of the Mbox before going that route. If you use keyboards a lot with VIs, or drum Vis, or want to, going to 64 Bit Pro Tools 11 may be an advantage. |
I hadn't looked into the Eleven rack at all until you mentioned it. Researching it now - pretty darn slick. If I can convince myself to drop the cash - I'm sure I'd be a very happy guy.
You will like it. Have a read of the PDF User Guide if you want to see all it can do, its well written. There is an Eleven Rack forum on DUC. Post any questions or problems there and you'll get good help. Also there are many Eleven Rack related videos on YouTube, e.g. Look for all the tutorials etc. by "BenoniStudio" -- an active DUC member.
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade | benosullivan | Pro Tools 9 | 2 | 11-17-2010 12:05 PM |
Compatibility Issue | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-07-2010 04:12 PM |
Compatibility - what is the issue? | GothicV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 01-12-2010 06:17 PM |
7.4 LE to 7.0 HD compatibility issue | Justin P. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-31-2008 07:35 PM |
1.25 compatibility issue | The Specialist | Pro Tools TDM Systems (Mac) | 0 | 03-22-2003 01:21 AM |
