#21
Re: Sidelined by CPU Problem on 32GB Mac
Sadly, no. If you need good performance, you need external SSD on TB or internal NVMe SSD -- both expensive in larger size.
#22
Any SSD on USB-C will be much better than your spinner, because by design SSD has minimal latency. Unless you need to use practically every library at the same time, that *may* be enough for you. With the USB bottleneck of course.
#23
I hope we will see more USB 3.1/Gen 2 USB drives in the 4TB capacity range soon and hopefully Thunderbolt 3/PCIe/NVMe drives as well. The NVMe SSDs are just so stunningly fast, but always be careful that any "Thunderbolt 3" drive is a PCIe/NVMe drive... some may only be SATA internally. If you did purchase an external USB SSD or SSDs today that might not be terrible... as you say you can use your HDD or clones/backups. But if curious if the drive performance is an issue one thing you might be able to do is copy only the samples you need to the boot drive and repoint Omnisphere to them. And test, just to see if there is an improvement. I don't have a feel for how large the libraries you might need are... but I've done this in the past with other sample based systems. |
#24
An external USB-C NVMe enclosure would be a lot cheaper than $1500 https://www.amazon.co.uk/ICY-BOX-Enc...s%2C161&sr=8-3 These are limited to 1000MB/s over USB-C but with the massively faster access time over a spinner you’re talking four times faster than your Glyph. Unfortunately 4TB NVMe sticks are still expensive but a Sabrent Rocket 2TB stick is less than $300. Even better one of these: https://eshop.macsales.com/shop/express-4m2 Add two 2TB NVMe sticks and it’s still a lot cheaper than $1500
Dave Marsden UK |
#25
I’m just watching from the outside and saw your section here about the UAD stuff... can you give me more info on this? I am always having pro tools is out of memory issues and I’m on a 64gb Mac Pro system ... I was wondering what the cause could be.. lmk your thoughts :) I appreciate it! Pro tools 2020 and Mojave in my studio FYI Sent from my iPhone using Tapatalk |
#26
#27
I run very few VI's in PT. Instead, I use the VST versions in VE Pro; that way PT is free to do what it does best...audio.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#28
As mentioned already a likely cause is using a lot of memory hungry VIs (how do you have the VI cache configured if it has one etc, How big do you have the Pro TOols cache set to? What VIs are you using? What standard troubleshooting have you tried? You are not actually providing much info here that is going to get you useful help). But we can't guess, you gave us *no* idea what you are doing except maybe running UAD plugins. And if it's not just VIs then a likely scenario is you have a plugin with a memory leak. There is a lot of standard troubleshooting you should try, starting with just trashing prefs. It's better if you just start your own new thread and provide all the expect info, including listing what troubleshooting you have tried. Start under the "Help us help you" link up the top of each DUC web page. Last edited by Darryl Ramm; 09-02-2020 at 10:31 PM. |
ProTools 10.3.5 & Mac Pro 32GB | alqadhi44 | General Discussion | 1 | 06-17-2013 09:12 PM |
...and in a puff of smoke, I was sidelined. | kooz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-19-2009 08:29 PM |
