Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 10-07-2012, 05:57 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default +4 dBu or -10 dBv analog in Omni
Hello.
Something I have not thought much about is weither to use +4 dBu or -10 dBv when recording through my Neumann M149 and Aurora GTQC preamp.
I notice that to get a healthy signal into Omni/Pro Tools at +4 dBu the VU meter needle on my preamp is going into the red area (right). The signal sounds fine tho. Not distorted.
Setting analog line input to -10 dBv the VU meter operates in the lower area (left). But the signal into Pro Tools is also fine at this setting.
Hmm, what do I ideally use, +4 dBu or -10 dBv ?
Old 10-07-2012, 02:24 PM
Default Re: +4 dBu or -10 dBv analog in Omni
+4 is generally considered professional and -10 is generally considered consumer. Most stuff we do with higher end gear should be at +4.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 10-07-2012, 05:15 PM
chrisdee's Avatar
Thanks.
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 02:00 AM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 10:19 PM
Are Omni Analog ins calibrate-able? Picture Start Pro Tools TDM Systems (Mac) 7 10-07-2011 09:07 AM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 06:42 AM
01V 18bit analog omni outputs? east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-07-2001 09:26 PM
