Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 09-26-2011, 10:01 PM
Mascola24 Mascola24 is offline
Default 9092, 9093 and 9129 error update?
I have been experiencing the dreaded 9092 9093 and 9129 errors that are all documented on here. All I am doing is recording a single naked track and they come up within seconds.
Avid, has any progress been made with regard to this issue?
While talking to Avid Tech Support on the phone, I tried uninstalling all 3rd party plugins, trashing the prefs + databases, and repairing the permissions. Also checked to make sure i did all the optimizations. This allowed me to track and playback... just long enough for the call to end, then started up again (my luck ). But while talking to the rep, he mentioned there was a possible BIOS settings configuration I can try, anyone familiar with this?
And just for clarity, originally I was receiving error -9093 and another error that said 'problem detected with audio clock. check that your clock source and sample rate are correct'. After I reconfigured everything, 9129 and 9092 started propagating. Don't know if this matters.
SiSoftware Sandra
Computer
Model : GigaByte Z68XP-UD5
Workgroup : WORKGROUP
Host Name : TactikAudioPC
User : Joey
Processor
Model : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
Speed : 3.8GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing
Computer
Mainboard : GigaByte Z68XP-UD5
BIOS : Award (OEM) F1 05/31/2011
Bus(es) : X-Bus PCI PCIe USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : No
Total Memory : 16GB DIMM DDR3
Chipset
Model : Intel Core (Sandy Bridge) DRAM Controller
Front Side Bus Speed : 100MHz
Channels : 2
Memory Bus Speed : 2x 667MHz (1.33GHz)
Memory Module(s)
Memory Module : Corsair CMZ16GX3M4A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Video Adapter : NVIDIA GeForce GTX 560 (336 SM5.0 1.7GHz, 1GB 4.1GHz, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GTX 560 (336SP 7C 1.7GHz, 1GB 4.1GHz)
Compute Shader Processor : NVIDIA GeForce GTX 560 (336SP 1.7GHz, 1GB 4.1GHz)
Compute Shader Processor : Intel(R) HD Graphics Family (6SP 850MHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics)
CUDA GP Processor : NVIDIA GeForce GTX 560 (336SP 7C 1.7GHz, 1GB 4.1GHz)
Storage Devices
WDC WD1500HLFS-01G6U0 (150GB, SATA300, 3.5", 10000rpm, 16MB Cache) : 140GB (C:)
Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) : 466GB (E:)
LITE-ON DVDRW LH-20A1S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
Hard Disk (C:) : 140GB (NTFS) @ WDC WD1500HLFS-01G6U0 (150GB, SATA300, 3.5", 10000rpm, 16MB Cache)
Hard Disk (E:) : 466GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm)
Optical Drive (D:) : N/A @ LITE-ON DVDRW LH-20A1S (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Giga-Byte Cougar Point LPC Controller
LPC Legacy Controller 1 : T2 87-28
Audio Device : Giga-Byte Cougar Point High Definition Audio Controller
Audio Device : EVGA 0E0Ch
Audio Codec : nVidia 0016h
Disk Controller : Giga-Byte Cougar Point 4 port SATA IDE Controller
Disk Controller : Giga-Byte Cougar Point 2 port SATA IDE Controller
Disk Controller : Giga-Byte 91xx SATA 6G Controller
USB Controller 1 : Giga-Byte Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : Giga-Byte Cougar Point USB Enhanced Host Controller #1
USB Controller 3 : Giga-Byte Renesas Electronics USB 3.0 Host Controller
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Dwight, you ignorant slut
Old 09-27-2011, 09:11 AM
Default Re: 9092, 9093 and 9129 error update?
Try disabling this in BIOS
Integrated graphics can be a show stopper(why I never recommend a Z68 motherboard).
Old 09-27-2011, 03:43 PM
Oh, wow. When I was researching motherboards, newegg gave me misinformation! it said that my motherboard did not have integrated graphics on it. If I knew this motherboard did, I would not have bought it.
I disabled the integrated graphics but the 9093 error popped up when I tried to test it. Do I have to reinstall Pro Tools for the configurations to take effect? I would prefer not to have to do uninstall, because last time I installed I had a firmware nightmare with the native card and I am not sure if uninstalling would wipe the firmware from the card.
Old 09-27-2011, 07:06 PM
I doubt a re-install on PT will matter, but its always a good idea to trash prefs after changing computer settings.
Old 09-28-2011, 07:10 PM
ok. i wish i knew you never reccomend z68 motherboards before I got it!
What motherboard would you reccomend?
9129, 9092, 9093 errors Jack Ruston Pro Tools HDX & HD Native Systems (Mac) 187 12-23-2012 02:19 PM
Error 9093 & 9092 please help!! travis_123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-09-2010 08:02 PM
Help! Errors 9092, 9093, 9094, 9129 persisting! doobaGeoff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-27-2007 07:32 PM
Interrupt errors -9092/ -9093/ -9094/ -9129 saxbill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-18-2002 12:41 PM
Studied all posts on 9092 9093 9129 however, these errors are still driving me NuTs! Wildberrie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 12-06-2001 06:10 AM
