Old 04-05-2007, 10:22 PM
Superbee Superbee is offline
Default Music Skips During Bounce to Disk
Has anyone had this problem. I have had the music skip during BTD a couple times now.
It does end up in the file. I am running HD2 on a Mac G5 Dual 2.0 OSX 10.4 ProTools 7.3
Let me know if you have a fix. I searched teh DUC but came up empty.
Thanks!
Brian
Old 04-05-2007, 10:27 PM
Default Re: Music Skips During Bounce to Disk
Also using Apogee 800's
Old 04-05-2007, 10:38 PM
bashville bashville is offline
Try searching again--I thought there was a thread recently about this.
Consider recording through a bus to an audio track instead of bouncing?
HD Ultimate (Native), PT2019.5, 192, 3.2 Quad MacPro 5,1, 16 Gig, Sierra
Old 04-06-2007, 02:45 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks!
Brian
Usual cause is the CPU nearing max and the bounce to disk just pushing it over the edge!! are you using RTAS plugs/instruments? if so try making the hardware buffer bigger, this will give more CPU headroom. are you using 1 or 2 RTAS processors in the playback engine! maybe try setting to 1 processor! if you are close to maxing the cpu then can you bounce any RTAS instruments or audiosuite any RTAS processors? you can also try different DAE buffer sizes, this sometimes helps! you can also try making the bounce region longer by extending both ends if possible.
Or, You can do RTD, record to disk, back on to a stereo track in the session! route everything to a mix bus(a stereo aux) the route that to a stereo track and record it into the session then use export audio region and send to your hard drive etc.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 04-06-2007, 02:20 PM
Excellent! Thank you!
Brian
Old 04-06-2007, 07:20 PM
Ray Lyon Ray Lyon is offline
BTD is unreliable with complex mixes using ADC, especially those with lots of automation, MIDI and VI usage. Putting the H/W buffer anything past 512 makes things sloppy with sync between MIDI and audio tracks. So recording the mix to another stereo track is the way to go.
Ray Lyon
www.raylyon.com
• Mac Pro 5,1 flashed 2009 model 4,1
• 12-core 2.93ghz "Westmere", 64 GB RAM
• OS 10.13.6 High Sierra, PT 2019.5
• One plug-in too many, but I really like FabFilter Pro-Q 3
• Avid HDX, Revive Audio modded Avid 192 I/O
• Avid MIDI I/O, Avid Command|8
• 256GB SSD, (2) 2TB ext. drive
• NVIDIA GeForce GTX 960 2048 MB
• Samsung 34" SE790C display (3440x1440), Acer 23" A231H Display
Old 04-10-2007, 11:11 PM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
I gave up on BTD a long time ago. I set up one of my buses to be "Stereo" just like a typical console, and I monitor on that for the entire session, then make an audio track at the end of the day and record it and "export as..." to .aif or whatever. There are so, so many advantages to doing it this way, not the least of which is last-minute tweaking as you're listening to the mix.
One major thing to watch if you're going to work this way...you have to set up the defaults in your I/O setup so that any new tracks you create output to the stereo bus, NOT to the main output of your I/O. I've been burned many times by tracks that were created late in a session that were sending straight to my 96 I/O instead of the stereo bus. It all sounds the same (or close enough to be fooled...) but those tracks are not, obviously, in your mix after all.
Good luck, it's ultimately a much better way to work. And the failures of automation during BTD are pretty well documented.
MacPro 2013, 12 core, 48G RAM
OS 10.14.6
Apollo x6 & Twin
Pro Tools 2019.10
Avid Artist Mix (2)
Old 04-12-2007, 08:17 AM
Oli P Oli P is offline
I'm using BTD...and have been for 8-9 years.
To me it actually sounds better, and I much prefer the workflow of having a dedicated master output.
My mixes have often tons of VI's running, and there doesn't seem to be any problems...other than the sessions that get totally messed up like the thread suggests.
But in those cases it always helps just to have one processor assigned to RTAS.
What baffles me, is that Digi doesn't respond to this issue at all
www.olipoulsen.com
iMac27 i7 3.4 / 32 GB Ram / ML 10.8.5
Apollo 8 / PTHD 10.3.9 / PTHD 12.4
Old 04-12-2007, 10:19 AM
DigiTechSupt's Avatar
Click on the 'Help Us Help You' link below my signature.
Avid Audio Tech Support
Support FAQ
Old 04-13-2007, 05:38 AM
Hmm...that sure helped
I do have my setup specs in my signature...and this problem only occurs every now and then...on some random session. I haven't been able to find a pattern in plug-ins or track counts etc.
But the remedy seems to be the "one RTAS processor" setting.
It would be nice with a simple explanation why the session can play perfectly well...and then screw up once you try to bounce.
www.olipoulsen.com
Beeps instead of Music during Bounce to disk robin.heinrich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-13-2010 05:23 AM
Music Skips During Bounce to Disk Superbee Pro Tools TDM Systems (Mac) 0 04-05-2007 10:22 PM
HELP! I CAN'T BOUNCE MY MUSIC TO DISK ANYMORE! madcollector2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-18-2004 10:38 PM
Bounce to disk HUGE POPS at end of burned music Jay Terrien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-03-2003 07:16 AM
skips after bounce aleeleota Digidesign Hardware & Software 6 06-07-2003 02:31 PM
