Old 03-22-2021, 10:45 AM
sw rec sw rec is offline
Default CTRL-ALT-B oddity
Just me, or does anybody else have this happen? Highlight session, go ctrl-alt-b for bounce to disk, and it clears the sound files. Ctrl-z puts them back, then the NEXT time I do ctrl-alt-b, it works. Not a show stopper, but it really shouldn’t be doing this. Pt ultimate 2020.12, latest Win H2 update that I really didn’t want.
Old 03-22-2021, 11:53 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: CTRL-ALT-B oddity
Ctrl+B is "Clear", similar to Delete, but only if something is highlighted. Personally, I would try a different keyboard.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-22-2021, 12:09 PM
Yep, just ordered a new one.
Old 03-26-2021, 07:35 AM
Update.....new keyboard, and still the FIRST time you CTRL-ALT-B it clears the highlighted files. CTRL Z puts them back, next CTRL-ALT-B initiates the bounce. Weird. Maybe a conflict with the 20H2 update. Guess I need to bite the bullet and install 2021.3.
Old 03-26-2021, 10:33 AM
The Weed's Avatar
No issues here with Ctrl+Alt+B, although 2/3 of that, Ctrl+B, is programmed into the "down" of my mouse wheel. I'll try the keyboard shortcut later today.
BTW, are you in Commands Focus mode? I ask because you're using Ctrl+Z for Undo rather than just Z.
SonoBus
Old 03-26-2021, 03:32 PM
Command focus is off. I have to get in the habit of not getting anywhere near the “b” key until I have pressed “ctrl & alt” first, apparently. Working pretty well having installed 2021.3.
Old 03-26-2021, 04:20 PM
The Weed's Avatar
This ^^^^
SonoBus
Old 04-02-2021, 07:03 AM
Prabha Prabha is offline
I've had the same issue... even with a programable keyboard.
The solution for me has been to pres them slowly one by one.
PC i79700K 4.8Ghz 32Gb ram Nvidia1050
Win 10 64
SSL MX4
Old 04-02-2021, 03:18 PM
I’ve adopted the same procedure. “Ctrl-Alt..........wait wait wait.......B.” Thanks! Guess I was just too dang fast.
Playlist oddity albee1952 Pro Tools 10 3 01-13-2013 05:27 AM
A VI Oddity with PT DonaldM Virtual Instruments 4 12-04-2009 10:22 AM
More Oddity problems Gothboy Virtual Instruments 0 11-24-2009 05:02 AM
No program changes with Oddity? Gothboy Virtual Instruments 0 12-14-2007 03:31 PM
ctrl+tab or ctrl+alt+tab not working Sebastien Richard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-09-2006 10:10 AM
