Xpand
i am fairly new when it comes to pro tools (About 6 months) but i have managed to find my way in most instances. however i don't know how to get audio out of the new Xpand plugins. i do have an error message that says there is no dat file on bank A. any suggestions and or solutions would be greatly appreciated.
Re: Xpand
Sounds like bad install. Uninstall is and run the setup again. Make sure to include the sound library for the plug as well when asked during installation. Once installed correctly there's nothing to it. It should work without a problem.
Hope it helps. |
Re: Xpand
i uninstalled and reistalled but to no avail. my limited expoerience tells me that plugins work with audio that is being tracked or audio that is playing back. how exactly does Xpand work? can i use the plug in to create wave files with the sounds in the library? im confused on this one.
Re: Xpand
If you are still confused, I would definitely recommend finding a book on MIDI basics and/or virtual instruments. Also, you never mentioned what version of Pro Tools you are using (or what operating system and Digi hardware); Xpand only works with versions 7 and up.
Xpand can't find the Xpand.dat | mountainman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-12-2009 12:24 AM |
Xpand.dat Gone/Xpand Crashes PT 7.4 | dts.music | Virtual Instruments | 2 | 09-16-2008 09:00 PM |
Xpand! | zombie69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-05-2006 05:35 AM |
Xpand! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-29-2006 07:39 PM |
xpand | meric | Virtual Instruments | 3 | 03-10-2006 03:48 PM |
