External Fire Wire Hard Drive Suggestions
Looking for a great priced external fire wire drive. I will be running Pro Tools 6.1 with a Apple G5 1,6GHZ. I know Digi says use a SCSI drive, but I don't care to.
Thank you, Maker |
Re: External Fire Wire Hard Drive Suggestions
Hey. I know these drives aren't cheap, but they rock........ wiebetech.com
They also make a oxford 911 bridge that makes cheap IDE drives into firewire drives........... check it out. |
I've got 4 of the Glyph Companion Drive (60GB a piece). They're great for swapping sessions back and forth between our 2 studios. I've never had a problem with them and having been using for about a year now. I will say that I have never had a session bigger than 24 tracks though. So, couldn't say how they'd work if you were doing a HUGE project.
If you're looking for ultimate speed, I would get a FW800 box from either OWC (Other World Computing), or WiebeTech. I prefer the latter, because their case is aluminum, and dissipates heat a little better. Then, get an 8 MB cache Western Digital hard drive, maybe like a 200 or 250. The big ones like that are faster than the 80s and 120s, mainly because of higher areal density. The Western Digital 8 MB drives are nice and fast, plus they have 3 yr warranty.
I would also recommend making a 15-20 GB partition as the first partition for running the session(s) off of. The rest of it could be storage, or you could split it again. Don't split a big drive into 10 equal partitions and run sessions off each one, because the last few partitions will be significantly slower (they are at the inside of the platter). |
I have seven Western Digital drives and am quite pleased with them.
Dan Matthews InSight Sound Recording Loveland, CO (970) 663-1650 InSight Sound Web Page |
Mac Book Pro Fire Wire will not talk to Digi 003 or External Hard Drive | jblaze | macOS | 5 | 05-27-2011 09:11 PM |
using external fire wire drive with macbook | jamal33 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-13-2007 07:56 PM |
need external Fire WIre drive | surely | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-07-2006 06:34 AM |
Best External Fire Wire Drive???? | darkglass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-21-2004 07:10 AM |
External Fire Wire Hard Drive? | CraigD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 09-25-2002 12:33 AM |
