Old 02-04-2012, 08:49 PM
LSNY LSNY is offline
Default "Conflict" between PT and Garage Band?
Running PT 9.0.6 on Macbook Pro. Lion.
Garage Band gets hung up and won't open. Won't respond, and has to be closed via "Force Quit".
I've done some research and found this: Something in the PT application messes with Garage Band. Anybody have experience with this, or know a work-around?
Old 02-05-2012, 12:46 AM
ejwells's Avatar
ejwells ejwells is offline
Default Re: "Conflict" between PT and Garage Band?
One workaround is to not use Garage Band.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 02-05-2012, 01:26 AM
ChuckS ChuckS is offline
If you using an Avid or Digi interface, search this specific forum for 'MIDI drivers'. It may be your problem.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-05-2012, 06:43 AM
Wise-guy (and unhelpful...although possibly funny) responses aside...
Thanks, Chuck, for the excellent tip.
I searched, and found info on the DigiDioMidiDriver.
Deleted that, and now Garage Band is back.
I don't need that driver for my set-up, and if I do I can always download a new one.
Old 02-07-2012, 06:46 PM
mwdoher mwdoher is offline
I'm having the same issue but don't have that same filename. Anytime I need to run something that requires MIDI to function, I need to insert my iLok, launch Pro Tools, minimize it, and then run the software. If I try to launch any of the following, it will not run unless I follow the steps I just mentioned.
Examples - and I use all on a regular basis as a Music Teacher:
Sibelius 6, Garageband, and SmartMusic
Any help you or anyone else can offer would be greatly appreciated. Thanks!
Old 02-08-2012, 06:43 AM
Rene van den Abeelen's Avatar
Rene van den Abeelen Rene van den Abeelen is offline
On my iMac that DigiDioMidiDriver plug-in has been moved automatically to a map called Incompatible Software.
That's clever & that's great, but why isn't Garageband starting up then?
Old 02-09-2012, 07:03 PM
Mike Glenn Mike Glenn is offline
Start Pro Tools before you start Garage Band then it will work.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
Sidechaining "band" stem compression off the vox track rlcowastudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-14-2009 11:35 AM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
"Be there" mix-plus demo - who are the band? tonygoodall General Discussion 6 02-28-2002 01:40 PM
