Old 12-06-2017, 06:30 PM
ByronC ByronC is offline
Default tracks flambing - delay compensation?
I'm having an annoying issue in PT 11.3.2 - I will, for example, hear the snare close-mic and then a split second later i'll hear the overheads.
This seemed to start literally out of nowhere. The other confusing part is that sometimes when I open the session, the issue won't be there. Then after several minutes of mixing, it re-surfaces.
Any thoughts?
Thanks.
Old 12-07-2017, 12:25 AM
Stig Eliassen's Avatar
Default Re: tracks flambing - delay compensation?
As long as ADC values are within limits (not red), you should be good.
Try to change buffer size in the playback engine next time it happens.
Studio rig - Pro Tools|HDX 2018.3 | Logic Pro X | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5
Mobile rig - Macbook Pro i7 w/16GB RAM | UA Apollo 8p | Pro Tools|HD 2018.3 | Logic Pro X | OS 10.12.6
Old 12-07-2017, 04:36 AM
Any thoughts?
Thanks.
Mac or PC? What operating system? You give zero system information. If OSX 10.10.5 I can check and see if I can duplicate the problem.
I remember a thread you started back in 2016 where you were losing tracks and you never got back to us if you solved the problem and how. What I'm getting at is this might not be a system problem but pilot error.
Old 12-09-2017, 07:06 PM
I've discovered a workaround but I still don't have an explanation for what the issue was.
Basically, the signal chain was as follows:
SnareTop output to Bus 6 (SnareSub)
Bus 6 output to Bus 1-2 (drumGroup)
The overheads went directly to Bus 1-2.
When I simply changed SnareTop output to bus 1-2, everything lined up just fine. There is clearly an issue with that bus6 not being delay compensated.
My system is PT 11.3.2 - MacBook Pro (mid 2012), OS Sierra 10.12.5
Old 12-10-2017, 04:38 AM
Good you got it sorted. However part of your problem maybe you're running PT11.3.2 on a non-compatible/non-supported OSX version. The last supported/compatible was OSX 10.10.5 aka Yosemite.
Old 12-10-2017, 10:36 AM
Thanks for that info regarding compatibility.. I honestly didn’t realize that.
Maybe time to just jump to PT 12...
Old 12-10-2017, 08:49 PM
Double bus routing is known to cause compensation problems AFAIK.
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Delay Compensation on AUX tracks - automatic mesaone Pro Tools 11 10 04-12-2018 10:26 AM
Instrument Tracks Delay Compensation Bug migueldgoncalves Pro Tools 12 5 06-29-2017 08:42 AM
How do I stop Delay Compensation from changing tracks? normbias Pro Tools Software (Mac) 0 04-19-2012 09:54 AM
Delay compensation and Aux Tracks Terry Wetzel Pro Tools Software (Win) 10 04-08-2012 07:19 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound Pro Tools Software (Mac) 1 01-27-2012 11:10 AM
