Errors galore
Setting up the lab computers at the college. Even attempting to play a BLANK track INSTANTLY yields an error #9093 (OS held off interrupts for too long. Increase h/w buffer) with a 512 buffer.
INCREASE the buffer to 1024 or even 2048 gives INSTANTLY a 9129 error, "audio processing is conflicting with other cpu tasks.try REDUCING the buffer size. Win XP/Mbox 2-mini/PT 8. Frustrating at best. Thanks in advance guys!!! (EDIT....we asked for SEAGATE drives but we GOT WD BLUE drives. Potentially the problem????) Sandra: SiSoftware Sandra Computer Model : HP HP Compaq 8000 Elite CMT PC Workgroup : LAB Host Name : PPCCCIA15617606 User : Administrator Processor Model : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed : 3GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel vPro Mainboard : HP 3647h BIOS : HP 786G7 v01.02 10/22/2009 Bus(es) : X-Bus PCI PCIe IMB USB Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DIMM DDR3 Chipset Model : HP Q45/Q43 DRAM Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DIMM DDR3 Memory Bus Speed : 2x 533MHz (1GHz) Memory Module(s) Memory Module : Freescale (Motorola) M378B5673EH1-CH9 2GB DIMM DDR3 PC3-10600U DDR3-1332 Memory Module : Freescale (Motorola) M378B5673EH1-CH9 2GB DIMM DDR3 PC3-10600U DDR3-1332 Video System Video Adapter : NVIDIA Quadro NVS 290 (16 SP 848MHz, 256MB DDR2 2x200MHz, PCIe 1.00 x16) Graphics Processor Storage Devices WDC WD3200AAJS-60M0A1 (320GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 298GB (C:) WDC WD3200AAJS-60M0A1 (320GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 298GB (D:) hp DVD A DH16AAL (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 298GB (NTFS) @ WDC WD3200AAJS-60M0A1 (320GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) DISK_1 (D:) : 298GB (NTFS) @ WDC WD3200AAJS-60M0A1 (320GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Optical Drive (E:) : N/A @ hp DVD A DH16AAL (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : HP LPC Interface Controller LPC Legacy Controller 1 : T0 19-11 Audio Device : HP HD Audio Controller Audio Codec : Realtek Semiconductor Realtek 662 High Definition Audio Serial Port(s) : 2 Disk Controller : HP Q45/Q43 PT IDER Controller Disk Controller : HP 6 port SATA AHCI Controller USB Controller 1 : HP USB UHCI Controller #4 USB Controller 2 : HP USB UHCI Controller #5 USB Controller 3 : HP USB UHCI Controller #6 USB Controller 4 : HP USB EHCI Controller #2 USB Controller 5 : HP USB UHCI Controller #1 USB Controller 6 : HP USB UHCI Controller #2 USB Controller 7 : HP USB UHCI Controller #3 USB Controller 8 : HP USB EHCI Controller #1 Printers and Faxes Printer : PDF Complete Converter (2400x2400, Colour) Network Services Network Adapter : Intel(R) 82567LM-3 Gigabit Network Connection - Packet Scheduler Miniport (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Re: Errors galore
I'm not an expert but:
Platform Compliance : Intel vPro-what exactly is vPro? Mbox 2-mini-Try different USB ports. Sometimes make all the difference Chipset Model : HP Q45/Q43 DRAM Controller-not sure if this is compatible Graphics Processor-is this a separate video card, or integrated onto the motherboard? Integrated will have the video ports next to the mouse/keyboard PS2 ports. As to the WD Caviar Blue drives, I am confused. I have some and they work fine, but mine are 16 mb cache, while yours are showing as 8 mb cache(not the source of the trouble, but may be a performance drain on bigger sessions). If you go into Setup>Hardware setup, are you able to select 2 cores for RTAS processing? If so, try it set to 1 AND again at 2 to see if it makes a difference. If you only can select 1, then something is wrong in BIOS. Also, review all your system tweaks(especially USB power management). And who set these up? Did they come loaded with a whole bunch of HP bloatware? If so, I would flatline them, and load in XP from scratch, without any of the extra garbage. Disable the network cards for now too.
Re: Errors galore
Re: Errors galore
Thnaks Albee...yes, tried both 1 and 2 processors and different USB ports to no avail. WIll try usb power management next. Fresh non-bloatware XP install, too.
Re: Errors galore
An update, and they all work just fine. Went into bios and set SATA POWER MANAGEMENT to "regular" and disabled the network cards. It works!!!!! Thanks Albee!
Re: Errors galore
Let's PARTY. I love it when a plan comes together. Thanks to TOM for the link....but it made my head hurt.....
Re: Errors galore
Mine too.
PT10 Errors Galore (Need help!) | cvdpoel | Pro Tools 10 | 2 | 11-18-2013 08:11 PM |
9129 errors galore | WarrenG | macOS | 0 | 10-17-2012 03:14 AM |
Errors galore...help!!! | Analog Kid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-07-2009 02:32 AM |
Errors Galore | ergalthema | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-29-2009 01:10 PM |
