Old 02-11-2009, 10:26 PM
stainless stainless is offline
Default Unused plug-ins
There are a number of plug-ins I do not use- I've tried them a few times and... I don't use them
on the possibility I might someday- is there a "best method" for moving them somewhere else... so if I should ever decide I think I have a use for it I can just move back?
I'm trying to streamline my drop-down boxes
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc
Old 02-11-2009, 11:00 PM
flommer flommer is offline
Default Re: Unused plug-ins
It is ironic, I suppose, that there is a folder in Library>Application Support>digidesign called "Plug-ins(unused)" which is exactly what you want (as well as the title of this thread aka. the ironic part)
The "Plug-ins" folder is in the same place and you can just drag them from the that folder to the unused folder..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 02-12-2009, 09:49 AM
Thanks- I knew about that folder
irony aside
I once used Digi's troubleshooting utitlity and it moved a number of plug-ins into the unused folder (some of which were digi bundled and others that were VST...) ... however when I moved those back I had to re-authorize the IK plugins that came with PT and rewrap the VST's-
That's what I'd like to avoid ....if that's possible?
Old 02-12-2009, 11:54 AM
Not sure about the re-authorizations etc.. but maybe it was because the troubleshooting app moved them, and did something else in the background like deleting the preference files or similar.
Old 02-12-2009, 12:19 PM
Premo Premo is offline
Ya moving the plug-in (dpm) file alone normally doesn't erase any authorizations (Even with IK). Each plug-in manufacture is a bit different, but with any serial authorized plug-in, there is a file usually somewhere in the user preferences or library prefs folder that stores the authorization. IF that file gets corrupted or is missing then the plug-in will ask for auth again.
So, for example you created a new user account, you might find that Pro Tools will ask for authorization on some of your 3rd party plug-ins again because you're using a new user preferences folder than the one that the plug-in was originally authorized on.
Old 02-12-2009, 12:21 PM
Richard901 Richard901 is offline
This program might be useful:
http://www.maisonsonique.com/index.p...-software_side
Richard
Old 02-12-2009, 03:29 PM
Richard901
Thanks! I'll take a look!
Deleting Unused/Unwanted plug-ins ThatSoundGuy5 macOS 9 01-05-2012 07:20 PM
Unused/Active plug ins folder, where is it? Bleeder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-13-2009 02:58 PM
Where is the Plug-ins unused folder on XP vudoo Pro Tools TDM Systems (Win) 1 05-02-2009 01:09 AM
6.1 TDM keeps loading plug-ins from unused folder! Dan Pinder Pro Tools TDM Systems (Mac) 18 10-23-2003 11:34 AM
select unused will delete unused jimlongo Pro Tools TDM Systems (Mac) 4 04-04-2001 06:39 AM
