Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 04-12-2013, 07:53 AM
CioneProStudio CioneProStudio is offline
Default Chaining 003 to Lavry A/D Converter
I want to try out the converters in a Lavry DA10 and hooked it up to the 003 via SPDIF. I could not seem to find any info on how to get the change over into the software. Any suggestions?
Thanks.
PT10.3.3
Nyla Cione
www.cioneprostudio.com
Mac Pro 12 Core OS 10.8.2
2 x 2.4 GHz 6-Core Intel Xeon
1 TB on Main HD
2 TB each on 3 Internal HD's (32 cache, 7200 rpm)
(total 7 gigs of storage)
16 gigs Memory
Old 04-12-2013, 09:10 AM
nst7 nst7 is offline
Default Re: Chaining 003 to Lavry A/D Converter
You need to determine which device will be the master clock (done in Setup>Hardware menu).
Note: You may have to make it the 003, as I don't know if the DA10 can be set to be the master clock. If it can, then definitely use the DA10.
Other than that, you will need to, on every track output in Protools that would normally go to your main outs, select the Spdif outs in addition to the main outs. If forget exactly how to select more than one output, I'm pretty sure you press the shift button first.
In addition, your master fader track would also be set to Spidf as the output.
Lavry Gold AD122 MK III Patheticus Buy & Sell 2 12-09-2012 10:33 AM
Lavry convertors with PT? Anyone using? johnnyv Pro Tools TDM Systems (Mac) 11 05-08-2005 11:35 AM
OT:Lavry Blue saturation rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-12-2005 11:02 AM
Lavry (dB) vs. other AD convertors ISedlacek Tips & Tricks 0 11-29-2003 07:37 AM
Anybody using the lavry blues, or the mytek 8/96s? Tetragamatron Pro Tools TDM Systems (Mac) 0 05-17-2003 10:13 AM
