Old 04-25-2010, 08:08 AM
ferry5 ferry5 is offline
Default NAtive instruments
Hi
I was looking for some NI stuff and i saw with the systemrequierments that it works under PT7 does this mean it doesn't with pt8?
Old 04-25-2010, 08:49 AM
mindnoise mindnoise is offline
Default Re: NAtive instruments
it´s the "minimal requirements" to run. Meaning anything older will not run.
but beware of OS X 10.6.3 in case you are on a Mac.
It seems to cause problems with NI and PT.
best
last: PT11.3.1
Old 04-25-2010, 10:22 AM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
I hadn't heard that until now. I'm using that combo on a couple different computers without any issues whatsoever. Maybe I'm lucky, but knowing the changes in 10.6.3 vs. 10.6.2 I'd be surprised if NI reacted differently under the newer OS. Where are you hearing about this?
Old 04-25-2010, 12:21 PM
over at the NI forum are some threads about having trouble with NI instruments after upgrading to 10.6.3.
esp. Battery. and AFAI remember on the DUC, too.
maybe they did something wrong - like not using the COMBO updater. etc. I don´t know.
best :)
last: PT11.3.1
Old 04-25-2010, 02:40 PM
Gothboy's Avatar
Gothboy Gothboy is offline
NI just updated Massive to 1.1.5 and for some reason I can't write automation with it. Also the standalone doesn't work right....the patches are all screwed up. So that's bad....
Looped sounds in it can now be auditioned correctly in PT though. so that's good.....
Can't they just get it right though?????
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 10/Presonus Studio 3
Old 04-25-2010, 05:23 PM
tlennon tlennon is offline
Hey Gothboy! I just left more info on NI forum. I turns out that more of the NI instruments don't record automation. I remain hopeful they will address this issue soonest.
Terrence Lennon
Ivory Key Productions
Old 04-25-2010, 05:47 PM
best :)
I see. Battery is good under 10.6.3, at least for me. I wonder what's causing those issues. Could be the OS directly, could be PT's interaction with the OS, could be the plugin's interaction with PT. Yes, could even be bad installs.
Old 04-26-2010, 03:56 AM
Gothboy's Avatar
You're kidding me!? What other instruments of theirs has this issue and is it just this Massive revision? How could any softsynth not do this at this point? You know, I tried recording automation with Massive 1.1.4 and it didn't work either. In the manual it says automation is possible...I wonder it it's an RTAS issue?
Thanks for adding to the shouting over there at NI!
16 GB RAM
Old 04-26-2010, 08:17 AM
Check your post at NI Goth
Terrence Lennon
Old 04-26-2010, 12:28 PM
Gothboy's Avatar
Thanks Terry. I can't believe that there's still no response from NI on the forum about this issue.
*pppfff*
16 GB RAM
Native Instruments - xfer fee for instruments? YYR123 Virtual Instruments 3 10-13-2013 04:47 PM
native instruments beright macOS 7 01-19-2011 09:32 AM
Native Instruments dope.as.one Virtual Instruments 1 03-03-2009 01:14 AM
Native instruments, help orenfarber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-04-2002 12:31 AM
Native Instruments Musichead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-23-2002 12:45 AM
