Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 03-07-2012, 08:37 AM
bilug bilug is offline
Default Drum Machine
Just curious if anyone has any experience or ideas on the best way to track from a drum machine.
I'm running PT6.9.2 with an MBox and use an Alesis SR-16 for my solo work.
It sounds good, but sounds like a drum machine with everything panned straight up the middle.
Any tips or tricks to taking the drums to the next level?
Old 03-07-2012, 03:13 PM
Default Re: Drum Machine
My tip; dump the box and check out Addictive Drums. Look at some demos on youtube or at xlnaudio.com. GC has it on sale right now for $99 and its a real bargain for great sounding drums and midi loops. Similar to ezdrummer(which I also own) but I think they did a much better job with it. You can filter the grooves so its much easier to audition them and find what you need to build your songs.
Old 03-08-2012, 10:55 AM
Thanks! Sounds like something to check out for sure!!!
Old 03-09-2012, 07:59 AM
nst7 nst7 is offline
If you want more realism, definitely check out software drum programs, like Albee mentioned.
Addictive Drums will be a huge improvement, and it's the cheapest right now.
You might also look at BFD2, which is on sale for March at $149 (however, I'm guessing that's because a new version will be coming out very soon).
There is also EZ Drummer and it's big brother, Superior Drummer 2.
EZ Drummer is on sale for $79.99 this month, and the expansion packs on sale for $39.99.
But, if you want to use your Alesis, your best bet is to run your sequence several times, each time recording individual drums to separate mono tracks (kick to track 1, snare to track 2, etc.).
This way when you're done, you can pan each one where you want, and add eq, compression, and effects as needed to each track.
Old 03-09-2012, 09:14 AM
That was the way I was guessing nst7....with a drum machine I'm pretty limited.
BUT..if I was to do that, would it be better to go MIDI?
I have NEVER used MIDI and am fearful of diving into that aspect of recording!
Old 03-09-2012, 12:08 PM
I'm going to go against the grain and say that that most drum machines have swing and swing can be added after the fact with Pro Tools Elastic Audio and Quantize.
Aaron Mulqueen - 001 HD Native
Old 03-09-2012, 03:40 PM
Filosofem...you know the style of music I play
Old 03-10-2012, 01:24 PM
ejwells's Avatar
ejwells ejwells is offline
You might want to have a peek at Steven Slate SSD4.
I have several drum programs (SD2, Addictive, Strike), but Slate is all I use now.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 03-10-2012, 08:02 PM
And SSD4 is on sale for $199 at Guitar Center this month.
Drum Machine evankertman macOS 1 01-09-2012 06:13 PM
dr3 drum machine anthony brown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-23-2006 10:05 AM
best drum machine/drum software robotman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 07-09-2005 12:09 PM
Drum Machine or Drum Software pacodub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-23-2005 11:29 AM
Making Separate Drum Tracks w/Drum Machine mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-02-2002 06:39 PM
