Old 07-30-2006, 10:57 AM
polaredit polaredit is offline
Default Tempo from analog drum machine doesn\'t equal click
Any help or replies appreciated,
Im setting up a click track at 95.
Setting up snap to measure.
Record analog drum machine (Boss Jamstation JS-5) at same tempo 95
PROBLEM: I check measure 4/1/00 Im dead on, Check measure 97, I'm off.
somethings up, is it the drum machine or do I have a setting wrong?
thanks
Old 07-30-2006, 02:57 PM
Jeff Ulmer Jeff Ulmer is offline
Default Re: Tempo from analog drum machine doesn\'t equal click
Unfortunately you have discovered what happens when you don't use a common clock signal - things don't sync up due to minute (or not so minute) variances in the clock.
If your drum machine can receive Midi Time Code, you should be able to sync it to ProTools - set the MIDI timing to remote (assuming you have a MIDI interface).
If you have recordings in the drum machine (from analog sources, not just MIDI or internal sounds being played back) you could record a drum machine generated click track back into ProTools and use the Identify Beat function (not sure if this is available in LE) to figure out the correct tempo, but you would need to transfer all the parts in the machine at the same time, since the timing could shift.
Recording artist/Engineer/Producer
Waves beta tester
Boom Drum Machine as click - how do i? Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-10-2009 02:26 PM
Timing Problem with PT Click and Drum Machine paul Neathery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-28-2007 02:23 PM
Sync drum machine to click track espada3 Pro Tools M-Powered (Win) 0 08-09-2005 09:58 AM
Newbie query on tempo, midi & drum machine James Young 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-29-2004 05:48 AM
Matching drum machine and PT tempo/beats Jay_Mora 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2001 03:55 AM
