Autotune bounce adds pops/clicks
In PT5.2.1 (1gig ram, G4, OS 9.2.2) when I bounce a track (usually a vocal) with autotune (v 3.0) on it, I've suddenly got some added pops and clicks in my new audio file. They seem to be random and will be different if I bounce the same file more than once, but I can't prevent them. Autotune settings don't seem to affect it.
I end up spending a lot of time removing them. Anyone else experience this problem? Any ideas on how to prevent it? |
Re: Autotune bounce adds pops/clicks
I've had this problem since day one when I bought Auto Tune. It seems also that we are no the only ones, there is another topic discussing this problem, but very old...
One of the workarounds I found is to process the bit of audio starting way before the waveform starts... let's see if I can explain this better. If you have a vocal track edited so that every word or sentece starts with the audio waveform, if you apply AT you'll get the mighty noise, BUT if you select the audio region and select also a bit before then the chances of getting those sounds are less. That's what I saw and what I always do now. So far Antares has not given me a correct answer to solve this problem. Normally one second before the audio region starts does the trick. Hope it helps. Al.
We are all in this together. |
Definitily, But I Would say that this hapens not just when you bounce the track. The polug in does it by itselp, You need to check, living it open for the whole track doesn't work at all...
Mac Dual 1.25 ghz "FW 800" 1024M ram. Digi 001 Scsi(64)-18 giga cheetah Ide 80 giga (7200) |
Ignored HL boy...
Regarding the use of Auto-tune, let me say something real quick.
Yes, I do agree that leaving Auto-Tune open for an entire session usually means that the singer could be a bit better, and you should try to fix it at the source with vowels, general pronunciation, and check out their moonitor mix and see if that have something to reference to. However, in a lot of pop music, especially vocal groups (like NSync), autotune may be used on the entire track to give them a perfect quality. But, I feel that a very very slightly off-pitch vocal part (like a cent or two) gives a track the same quality as analog warmth would give to a digital chill. Normally I will leave it open in auto-mode for an entire song to just see where the problem areas may be (cause it may be tough to tell in a dense mix), and then just apply it to that area with the graphical mode. |
I have to say that You just said the perfect way to use it.
Most of cases I use graphical mode, and when I wanna correct the part that I processed, I never ever use audiosuite to do it. Because You'll have to listen the track all over and check if have click, pops, or wrong tunning. I always Bus to another track and record it, and solo both tracks to be shure that nothing "weird" will happen, than I replace in the original track the part that I just fixed. Leaving the auto-tune for the hole track almost never work in auto. Once and while You'll get "Maddona" auto tune effect on some word, when you ashlly didn't want it. I would say that, trying to correct the hole track leaving auto tune in auto position, it's a Lazy engineering in my point of view. For doing that, Melodyne Works much better. Have a good one.
pops / clicks in Autotune? | tworooms | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 11-13-2017 07:53 PM |
PT 7.4 LE Bounce Issue -> Pops, Clicks | Rotbart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-07-2009 12:00 PM |
Clicks and Pops on Bounce? | Snitz | Pro Tools TDM Systems (Mac) | 0 | 12-19-2005 05:34 AM |
RTAS Autotune 3 + 6.9 = clicks & pops? | Blackfoot | Pro Tools TDM Systems (Mac) | 4 | 05-10-2005 12:54 AM |
clicks and pops during bounce to disk | jigidyjim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-28-2004 01:11 PM |
