Old 06-19-2001, 10:34 AM
India001 India001 is offline
Default Removing "Ph" and "S" sounds in vocals
I was trying to remove the "Ph" sound in a vocal track.I thought De-essar would do it for me.But I was not able to do so after experimenting with the various settings.Then I tried the Gate - Mono.I kept all the default settins and only changed the attack to 34ms.I was able to remove the "Ph" sound .My question is:
1) Am I doing right?Is this the only way.What you guys do in this situation?
2) How to remove the "s" sound?I am not able to remove it.Not with EQ, not with De essar and not with Gate.I know I do not know what parameter to adjust.
Please help .
Old 06-19-2001, 07:11 PM
Default Re: Removing "Ph" and "S" sounds in vocals
Thanks a lot.I will try that.
Other suggestions are also welcome.
Old 06-20-2001, 12:42 AM
Mr_Seven Mr_Seven is offline
To remove the "esses" you'll want to dup that track and boost offending frequency serveral db. Then use that track to trigger a compressor via the side chain to effect the original track.
[ June 19, 2001: Message edited by: Mr_Seven ]
Darren Valen
Cyberdream Studios
Old 06-21-2001, 07:05 AM
Soundboy99 Soundboy99 is offline
Check www.artistpro.com
They have on-line classes there that teach you a lot on this kind of stuff. I remember under "Dynamics" topic I read about doing the same thing someone just said: Run the sound through an EQ, boost the frequencies causing the problem, then run the new sound through a compressor with the appropriate ratio so that those problem-frequencies get compressed.
However be very carefull with attack & release time setting:
"If the attack time is too fast, the compressor will turn down the transients. This can cause an instrument to lose life and clarity. On a vocal, for instance, if the attack time is too fast, all of the “t” and “s” sounds will start to disappear. On the other hand, if the attack time is too slow and the vocal is very compressed, the t’s and s’s will fly through uncompressed and sound exaggerated"
[img]images/icons/rolleyes.gif[/img]
Rock Da Sound!
Old 06-21-2001, 01:02 PM
TriAxis TriAxis is offline
Or just buy a WindScreen, they wont fix everything but they help alot [img]images/icons/shocked.gif[/img] [img]images/icons/shocked.gif[/img]
TriAxis Wuz Here!
DIGI003 Rack+ Factory
Intel Q6600, ASUS DH Deluxe, 8 GB DDR2 800 Mhz RAM,
ProTools LE 10 on Windows 7 64 Bit
Old 06-21-2001, 02:59 PM
[Benjamin] [Benjamin] is offline
Okay, in order:
1) Windscreen for Ph's, and hopefully catching the esses enough aswell
2) Use some easy-come-off glue and put a match vertically in front of the mic.
3) The De-esser works, too. It just takes a while to get it right.
4) Side-chain compression (Which is exactly what a de-esser does, but if you need more control, which I doubt)
/ Ben
www.bipeds.tk
Old 06-22-2001, 03:14 PM
Toney Robinson Toney Robinson is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by [Benjamin]:
<HR></BLOCKQUOTE>
I'm not familiar with this. Is this some kind of joke? If not, please supply more detail. [img]images/icons/confused.gif[/img]
Old 06-22-2001, 06:24 PM
Mark_Knecht Mark_Knecht is offline
The actual settings you use might be very dependant on your vocal track, but I would certainly appreciate soemone publishing the exact setup they're using to fix this sort of problem. What plug-ins, what sort of bus routing, etc.
This is great info.
Thanks,
Mark
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Blocking the "P" and "F" sounds in vocal tracks. ice0-5 Tips & Tricks 6 03-18-2011 10:20 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
minimising mic "sss" and "tttt" sounds in singing Matt Darcy General Discussion 7 09-12-2008 06:47 PM
Removing "P" Pops in vocals? MARVINBASS Pro Tools TDM Systems (Mac) 5 07-15-2002 11:59 PM
