Old 11-25-2009, 08:58 AM
the barn studios the barn studios is offline
Default Quick Way to activate all "inactive" inserts
Hey guys, this may be a fundamental question that I've never known.
When passing a session back and forth between systems you get missing plug-ins (if you don't have them on the other system) which then become inactive inserts. When opening up again on your main system, what's the fast way to tell all your italicized plugs to "get active" without manually doing each one? Thanks if this is a basic one. -CS
Old 11-25-2009, 09:27 AM
allstaar's Avatar
allstaar allstaar is offline
Default Re: Quick Way to activate all "inactive" inserts
Command+Option+Ctrl will reactivate plug-ins on an insert for all tracks which will significantly speed up this process. I'm not a Protools system right now, but I think you can add Shift to that too to reactivate plug-ins on an insert row for all selected tracks.
The input path "S/PDIF L-R" was made inactive because its stem is missing. ampnerd macOS 3 02-05-2014 08:58 PM
"The licensing service required to activate this software is not running." cmhawke Pro Tools 11 3 08-04-2013 04:41 PM
soft samplecell rendered "inactive" when loading pro tools LE 5.1.1 Charles Aarons Digidesign Hardware & Software 0 04-20-2003 11:54 AM
PT 6 breaks S/PDIF "out" and "inserts" on I/O setup wcody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-04-2003 05:14 PM
Option + SpaceBar = "Waiting For Sync"...how do i de-activate this? Felix Tips & Tricks 0 12-02-2001 12:46 AM
