Drag and Drop Audio Files to timeline - very slow
Hey there, Pro tools is acting odd when dragging an audio file to the timeline. its taking ages until the file comes up in the timeline. what could be the reason for this, it used to work fine before?
Re: Drag and Drop Audio Files to timeline - very slow
Dragging file from where? Region list? Finder?
Have you tried trashing prefs? Tamas Dragon
my blog:Tamas Dragon |
check if elastic audio is enabled on the track and turn it off to see if that is causing the delays. This can certainly take time if a busy audio track is imported and then needs to be analysed by the EA algorithm.
Sorry I didn't specify, I'm dragging files from the finder into a non elastic audio track.
Thanks for your help |
Than the delay can be that pt is importing (copying, etc.) the files.
Tamas Dragon
Thanks Tamas,
The delay could take up to 1 minute per a 20 sec file http://img139.imageshack.us/img139/9468/picture5scl.png Here's another issue which may be related, this message comes up when attempting to separate audio regions without elastic audio enabled. |
Ok, so instead of draggin' files from the finder, use import audio menu.
regarding the error. http://web.mac.com/jcdeshaies/Delete...Bienvenue.html download the tool, and delete everything with it, that should solve this issue you've had. Tamas Dragon
Thanks for the solution :) I'm sure there is another way to solve this as it was working fine before. I'm on a new system and have trashed my preferences files without any luck.
When I had this error, deleting the digisetup.osx helped me. Trashing prefs did not helped me either.
The other thing, I never dragged files from finder, so cannot comment on that workflow. Tamas Dragon
Where is the digisetup.osx located? Thanks.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Can't Drag and drop on timeline | drorsh4 | Pro Tools 9 | 1 | 04-05-2012 12:24 AM |
Cannot Drag and Drop Audio Files :( | NateMo80 | Windows | 1 | 08-31-2011 01:07 PM |
Windows Explorer drag and drop audio files to PT8.0.3 | Buccanears | Pro Tools TDM Systems (Win) | 9 | 03-20-2010 09:05 PM |
drag and drop audio files | peter99 | Pro Tools TDM Systems (Mac) | 2 | 02-04-2009 02:02 PM |
drag and drop corrupting audio files recorded by HHB | Johanna Herr | Pro Tools TDM Systems (Mac) | 2 | 05-08-2007 11:52 AM |
