Old 12-06-2003, 07:55 PM
ndlsd ndlsd is offline
Default intstalling protools for multiple user accounts
I asked this question in another thread but it never got answered so I'm making it it's own topic. How do you install protools so it works across all the administrator user accounts on a single computer? Is this actually possible?
Old 12-06-2003, 08:21 PM
Default Re: intstalling protools for multiple user account
Yes, it is possible.
*WARNING*If you use TC|Tools, do NOT create more than one admin user! If you create more than one admin user, the TC|Tools will not work unless you do a clean install of OS X!
Now, if you still want to do it, it is very simple. Install Pro Tools under an admin level user, and create as many admin level users as you need to. Then all you need to do for each user is the usual first launch dialogs (what interface, where's the WAVES folder, etc). The only problem you will have is with Plugins claiming to not have resources (DAE error 700x). If you have available DSP, this means that the permissions aren't set properly. I've found, for example, that Sound Toys' UltraTools needs to have the group set to staff (not admin) with read/write access to work with multiple users.
It involves a little extra effort, but nothing you can't handle if you know how to create users.
Good luck.
Old 12-06-2003, 08:36 PM
B-Grade B-Grade is offline
The problem is not with Protools, but rather the way certain plugs work. TC tools was mentioned, but the IK stuff, amplitube and more need to then be registered with each account. A big ol pain in the butt for sure.
Mac Pro Rack - Ventura
PT 23.12
HDX - MTRX Studio
Mac M2 13" Air in the field
Multiple User Accounts G5 PT TDM 6.7 HELP brinaddison Pro Tools TDM Systems (Mac) 7 11-06-2010 05:54 AM
Does anyone use multiple user Accounts on a MAC with Pro Tools? kd_special Post - Surround - Video 12 09-15-2010 04:10 AM
is multiple user accounts are working? tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-07-2009 01:07 PM
Problem with LE 7.1 and multiple user accounts djaikon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2006 04:38 PM
PT 6.01 and multiple user accounts houser Pro Tools TDM Systems (Mac) 3 04-29-2003 07:07 AM
