Old 03-14-2016, 03:35 PM
rhumphries rhumphries is offline
Default Pro Tools 12, initializing audio engine
I've just installed Protools 12.4 from scratch on a freshly formatted drive with a fresh install of El Capitan on a mid 2010 8* core Mac pro (5,1). I'm Running an HD Native card (slot 4) and an HD Omni.
I can boot protools using the computer's line out, but when I switch to HD native it hangs.
Any ideas?
•Edited-- It's an 8 core, (2x2.4 Quad) not 12
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
Old 03-15-2016, 04:26 AM
Bookerv12 Bookerv12 is offline
Default Re: Pro Tools 12, initializing audio engine
Did you install the HD driver?
bookerv12
Old 03-15-2016, 06:22 AM
Yep. Installed the HD driver. Everything in the Application manager says it's up to date. I even did a clean uninstall and re-installed from scratch again with the same results.
www.TakomaMedia.com
Old 03-15-2016, 10:44 AM
Solved. Had to reset the Omni.
Hit the Setup button on the right front panel of the HD Omni so that it lights up green.
Turn the MONITOR encoder to right a few times so that the display says CNTRST, click back one click to the left and it should say RESET.
Press the MONITOR encoder button to select RESET.
Press the MONITOR encoder button again to confirm RESET.
Next, power off the HD Omni for approximately 30 seconds, then power it back on. Restart your computer and launch Pro Tools HD.
www.TakomaMedia.com
Pro Tools hangs at initializing audio engine kasman Pro Tools HDX & HD Native Systems (Win) 12 05-10-2016 09:20 AM
Pro Tools Initializing Audio Engine Error kdro Pro Tools 12 10 08-14-2015 01:12 PM
Freeze at Initializing Audio Engine maunaloa Windows 0 04-14-2015 05:42 PM
Pro Tools 11 and MBox 2 Pro hangs during Initializing Audio Engine SBeats123 Pro Tools 11 5 01-15-2015 03:59 AM
Pro Tools 11 stuck on "Initializing Audio Engine" AudioDrummerGuy Pro Tools 11 10 01-19-2014 12:47 PM
