  #301
Old 09-10-2021, 11:19 AM
its2loud its2loud is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
Originally Posted by Audio Editor View Post
Hello all,
I have heard many great things about Keyboard Maestro. However, I would be interested in a solution that would allow me to continue working with the automator. Has anybody a Solution ?
Fastscripts has been mentioned in the thread but I have not used it. I just haven't had the time to debug why the script executes Render three times when executed. KM has been my solution.
Maybe post your script to see if there are any issues within.
  #302
Old 09-12-2021, 06:26 AM
Audio Editor Audio Editor is offline
Hello all,
I have attached the code of my script which has worked for years.
PHP Code:
tell application "System Events"
tell process "Pro Tools"
set frontmost to true
if exists (window "Audio Suite: iZotope RX 5 De-click"then click button "Render" of window "Audio Suite: iZotope RX 5 De-click"
end tell
end tell
I think something in Pro tools has been changed so that this script no longer works.
Thanks in advance
  #303
Old 09-14-2021, 12:33 AM
Oliver M Oliver M is offline
Hello all,
PHP Code:
end tell
end tell
Thanks in advance
this works fine here with Pro Tools 2021.7.
  #304
Old 09-14-2021, 06:13 AM
Originally Posted by Oliver M View Post
Oliver, if you create a Pro Tools Service with this script and then execute the service using a Mac OS shortcut key, do you get the triple click of the Render?
This was my issue I posted a couple of weeks ago. Seems like Audio Editor is having a similar issue.
This might be an OS issue rather than a Pro Tools issue since the script runs fine when test in Automator or Script Editor.
I’m on 11.4 w Mac Mini M1
  #305
Old 09-15-2021, 01:21 AM
It seems like you have to carefully choose the shortcut.
Example: Using the shortcut ⌃⌥⌘+Y does not work, it triggers the script 3 times.
⌃+Y works fine though. Play with the shortcuts or stick with Keyboard Maestro or FastScripts. 😉
  #306
Old 09-15-2021, 02:21 AM
Hey Oliver,
thanks for testing. Unfortunately I can't reproduce this on my system.
For years the default setting for me was ⌘+f16. No matter which combination I used each time the script seems to be executed 3 times.
Neither ⌃⌘+f16 nor ⌃+c changes anything.
  #307
Old 09-15-2021, 04:27 AM
Hey Oliver,
thanks for testing. Unfortunately, I can't reproduce this on my system.
For years the default setting for me was ⌘+f16. No matter which combination I used every time the script seems to be executed 3 times.
  #308
Old 09-15-2021, 05:23 AM
Awesome! Thanks for testing on your end. When I have time I’ll do some more digging but this good to know. KM it is for now.
Funny. I wasn’t using any modifiers with my shortcut key. It was simply F17
  #309
Old 09-16-2021, 12:15 AM
Hey all
thanks for testing.
My RX shortcut in the last years was ⌘+F16.
Unfortunately it doesn't seem to matter which assignment I give the script is always executed 3 times.
Seems like I really need to make friends with an alternative to Automator.
  #310
Old 10-01-2021, 12:17 PM
This is such an annoying bug in the Mac OS. I'm only witnessing it in Catalina and Big Sur.
If anyone has an OS based workaround please post it in this thread. Thanks
Pro Tools 12 Trim Automation [email protected] Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
