Old 08-23-2014, 12:25 PM
kevinjrowe kevinjrowe is offline
Default Pro Tools 11 hangs up at "loading midi engine" step for 10 minutes
When I load protools 11 with my Apollo Twin DAW on my macbook pro running mavericks, it hangs up at the step "loading Midi Engine" for ten minutes. Eventually it loads and works but this doesn't seem normal. What can I do to fix this?
Pro Tools "install hangs at Installing Digidesign hardware drivers" Bulley Pro Tools M-Powered (Win) 12 08-16-2012 07:53 AM
Pro Tools 9 Hangs "Setting up MIDI" FranklynJones Windows 8 12-19-2011 02:21 PM
PT 10 Hangs on Pgm. Boot at "Setting up MIDI" billborg Pro Tools 10 4 10-26-2011 11:11 AM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
Pro Tools le 6.0 (and 6.0.1) hangs on "setting up Midi"-- then unexpectedly quits rdatman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-19-2010 09:15 PM
