Downgrade from 7.4 to 7.1
Is it possible to downgrade from 7.4 to 7.1 or even to 7.3? I notice that almost all digidesign hardware on even sites like eBay are all shipping with 7.4. However, even if I purchase 7.4 I would still like to use 7.1, especially because I use FAT32 drives (as they are cross-platform) to do work all over many various studios. Also, 7.4.2 as far as I understand is compatible from OS X 10.5 and upwards, whereas 7.1 - 7.3 is compatible with OS X 10.4.x As you can imagine, why bother spend more money upgrading OS just so I can run ProTools? At the end of the day, is it really worth it?
Last edited by mixupandblend; 08-13-2008 at 11:34 PM. Reason: forgot to add information |
Good Day!
Speaking thru experience, Migrating back to 7.3 or 7.1 will be a quick and easy process. Just use the "uninstall protools" on the application/digidesign/protools utilities before installing a new protools version. Also, You will need the appropriate serial for the that version. Regards, Joey |
Will digidesign supply that software for me? I know it's probably unheard of because everybody wants the latest software. It's just that the LE systems I am buying all come with 7.4 so I really have no choice. I am buying them from eBay
You are better off looking for a used 002 rack on ebay. you can not find a 002 or a version of pro tools under the one that is currently out now in stores. you're only real bet is eBay or here if someone is looking to sell 002 hardware/software. hope this helps.
http://cgi.ebay.com/Pro-Tools-Digi-0...d=p3286.c0.m14
check that out. i'm not too sure if thats exactly what you are looking for, but you can find plently of good used gear on eBay. |
HELP! I need to downgrade! | bigTimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-30-2012 02:03 AM |
how to downgrade from 8.0.3 to 8.0.1/8.0 | krisjan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-01-2012 04:13 PM |
PT LE8 to PT LE7 downgrade | fuztec25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-06-2011 01:28 AM |
downgrade from 8.0.1 to 7.4 | Micah777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-20-2010 04:22 PM |
How to downgrade to 10.4.8????pls pls pls help! | Kstyle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 03-20-2007 11:11 AM |
