MOJO SDI Video Stutter
I have just installed a new Mojo SDI into my PT 7.4 HD system running on a dual 2.7 G5 and was shocked at the quality of the Video output. I have been using a Canopus up until now and was looking for something better. All the video files are DV25 quicktimes generated on FCP and have played reliably on other systems. I did find the High Quality Quicktime output setting so that the system plays both video fields and it made a quality difference, however I am still seeing a stutter in the video output. This is not evident when using the canopus. This stuttering is also evident when using mjpeg A and H.264 files.
Has anyone else seen this? Any suggestions? Thanks |
Re: MOJO SDI Video Stutter
Which port on the Mac do you have the MOJO connected to? Are there any other firewire devices connected (there shouldn't be)? Are you playing the video from a separate drive from your audio?
About the Video stutter | soundworx | Post - Surround - Video | 7 | 11-16-2010 09:40 AM |
PT 8.0.4 still problems with Video Stutter with HD 1080 file | Eric L | Post - Surround - Video | 19 | 10-28-2010 05:24 PM |
Video Satellite LE Stutter (unsupported system) | TDD | Post - Surround - Video | 0 | 03-18-2009 08:08 AM |
7.4 and Mojo video stutter | TAFF | Post - Surround - Video | 11 | 12-01-2007 02:27 PM |
Mojo picture stutter | dbcsound | Post - Surround - Video | 7 | 04-04-2007 07:33 PM |
