Old 06-18-2018, 03:40 PM
Steve Garman Steve Garman is offline
Default What kind of tracks are these?
I have tried to make a new track that is like these but every category I chose is not these. They have no fader knobs and only an input and rec switch. I want to use these in a new session but I can only duplicate them in this session and can't figure out what they are so I can make a new one in a new session from scratch. Do these look familiar? Thanks for any help. Picture is attached.
Old 06-18-2018, 05:35 PM
Tweakhead Tweakhead is offline
Default Re: What kinf of tracks are these?
They are stereo audio tracks, each of which has its output assigned to a mono bus. They have their "Input Monitor" button engaged, and a test signal (probably timecode, judging by the name) is being sent to their left input channel (ie input #3 of your audio interface)
Why . . . only you can explain ;-)
Old 06-18-2018, 06:48 PM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
Exactly! This explains why you're not seeing any PAN controls.
(I'm assuming that is the issue here..?)
T
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
Old 06-19-2018, 11:43 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: What kind of tracks are these?
As Tweekhead said they are "stereo audio" tracks BUT the output is assigned to a mono bus
I am a little bit confused , because they actually do have "Fader Knobs " they are the red rectangular buttons sitting at 0 db in the slider scale.
I am guessing the problem you are having recreating them is PT is probably defaulting to the stereo main outs for any new stereo audio tracks, so you will have to create the tracks then select a mono bus from the dropdown when you click on the output selector button.
Also note they are Input monitoring engaged and are record armed (thus the red faders )
System :
Enjoy the Journey
.... Kev...
Old 06-19-2018, 05:14 PM
Originally Posted by K Roche View Post
snip . . . I am a little bit confused , because they actually do have "Fader Knobs " they are the red rectangular buttons sitting at 0 db in the slider scale.
I think he simply used the wrong terminology in his original post. I am guessing that he was actually referring to the missing "Pan Pots" (because of the direct mono assignment), and instead mistakenly called them "Fader Knobs".
Old 06-20-2018, 05:55 AM
K Roche's Avatar
Ah, yes the internets can be communication challenged
System :
Enjoy the Journey
.... Kev...
What kind of Mac is best?? Help! galaxy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-06-2009 01:05 PM
what kind of pc should i buy thuglord Pro Tools M-Powered (Win) 2 08-06-2009 02:21 AM
what kind of RAM? arnobg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-28-2009 09:28 AM
What kind of mic-pre is in a 002? Soliton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-08-2005 03:27 PM
This has nothing to do with PT...well kind of... Nine Spine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 38 02-09-2002 12:17 AM
