Old 01-14-2014, 03:38 PM
TheStudioGuy TheStudioGuy is offline
Default What causes this weird crackle?
Here's a bass track from a project I'm working on. The audio has a crackle. Here's what it looks like. Any idea what causes this?
File Type: jpg Screen Shot 2014-01-14 at 6.32.09 PM.jpg (53.7 KB, 0 views)
JP
Old 01-14-2014, 06:55 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: What causes this weird crackle?
I would need to be able to hear it, that may help. It can be any guess as to what it is....bad patch cable, if a pedal was used, damaged soldering in the bass etc....It would be safe to say that whatever was recorded had some form of distortion pre A to D.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 01-15-2014, 08:56 AM
There's no distortion really, just a crackling in the top end.
The signal path was Roscoe Bass(Active) to Grace 101 Pre to HD IO.....
Thanks.....
JP
Old 01-15-2014, 09:42 AM
DetroitT's Avatar
DetroitT DetroitT is online now
Sound to hear would be more useful.
"crackle" throughout the recording?
Old 01-16-2014, 06:48 PM
dr_daw's Avatar
HA...ok. Well, I don't mean distortion in the sense of Pantara or Slayer. I mean in the sense that it is an alteration of the the original or expected waveform. That crackle in the high end, is a form of distortion in that it is NOT there originally.
From second glance, the period of the 'distortion' it seems like it is definitely something time based. Again, an audio example is the only way to be able to hear what is going on. There are plenty of us on here that can tell the difference between a clocking crackle and a bad solder. Without that you're shooting in the dark looking for a response. From what I can see though, your best option is to re-record the bass. Outside of that, look for whatever izotope plug that will rid crackles from s***ty recordings.
Rig
Old 01-16-2014, 11:41 PM
Rob Da Silva's Avatar
Rob Da Silva Rob Da Silva is offline
Just a s-w-a-g but it looks like the active circuit needs a fresh battery. Roscoe makes kick-ass basses but they are only as good as the power supply. I've seen this in 3-band circuits when batteries start to drop voltage. It always affects high freqs first. If that fails, swap out the cable to Grace. Next in line would be the cable from Grace to HD IO.
Good luck.
Rob Da Silva
Owner/Producer/Engineer PurpleCatAudio LLC
MAC Pro Intel 2x2.4 Quad-core Xeon 24GB OSX Lion 10.7.5 HDX 16x16 I/O PT11.0.1 C24 Control Surface
Crackle songman macOS 0 11-19-2011 12:28 AM
crackle Ronnisi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-07-2011 05:36 PM
crackle, crackle Zoolander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-29-2003 09:30 AM
Crackle in Mix frones jones IX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-21-2003 04:34 AM
rf crackle removal Zale Dalen Digidesign Hardware & Software 12 11-16-2001 06:11 PM
