Old 10-19-2012, 10:26 PM
jackp jackp is offline
Default C/24 sends view ?
When adjusting the send volumes from the C/24 f thru I , is there a way for the send view on the computer mix screen to actually see the little fader move when adjusting from the c/24
Thanks jack
Mac Pro 8 core Protools 10 HD 4 Accel PCI with Magma, C/24 with 2 192 I/O
Isochrone clock
Old 10-21-2012, 09:02 PM
Rob Da Silva's Avatar
Rob Da Silva Rob Da Silva is offline
Default Re: C/24 sends view ?
On the mix view you need to have the send highlighted so the send view shows up (if I understand the question).
Press the send button on the channel.
Display shows sends a-e.
Press channel bar scroll "more".
Display shows sends f-j.
Press the switch functions button corresponding to the send insert on send f.
Rotary knob works the volume as labeled.
Press flip if you want that to be operated thru the fader.
I wish AVID would have given this view as a simple function button for sends.
I feel the pain but I only use this for headphone mixes where I want the artist to hear something different than what I get in the CR.
Hope this helps.
Rob Da Silva
Owner/Producer/Engineer PurpleCatAudio LLC
MAC Pro Intel 2x2.4 Quad-core Xeon 24GB OSX Lion 10.7.5 HDX 16x16 I/O PT11.0.1 C24 Control Surface
Sends Expanded View Mount Royal Pro Tools TDM Systems (Mac) 9 04-20-2019 07:13 PM
View multiple sends in fader view. yamahadrums Pro Tools 9 6 03-07-2012 06:53 AM
Shortcut to view sends? soundboy35 macOS 2 03-20-2011 03:45 PM
6.1.1 sends view mixerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-05-2004 06:54 AM
Multiple sends view on mix window Kenshiro Pro Tools TDM Systems (Mac) 0 11-06-2001 02:02 PM
