getting rid of background noise / hum
I did a search for 'background noise' and didn't get much...
when I record my acoustic guitar with my NTK, of course, I turn everything off: fans, tv's, anything that makes a significant noise.. are there any tricks to get out the rest of the noise that is still there.. if the acoustic guitar is in the mix with other stuff, there is nothing noticable, but if i put this guitar in the beginning all by itself, you can definately hear just noise.. are there frequencies commonly associated with this that you can cut out, or maybe use a gate, or any other tricks to get that studio sounding acoustic.. thanks tim |
Re: getting rid of background noise / hum
What is the noise? Do you hear it while the guitar is playing, or only in the quiet parts in between notes or chords?
Quad 2.5 G5, 4.5G RAM |
A gate or expander will get rid of most ambient noise. Hum will require EQ - Waves has settings to eliminate hum. Play with plug-ins on your noisy tracks and see how well it works
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
no hums that i can tell, its just noise that the mic is picking up.. ambient stuff.. |
treat the room or use better isolation to eliminate the noise. If it an AC hum problem, look to your system wiring and AC source and correct the problem. Either case, find the problem and make it right, don't try to fix in the mix.
If this is a track already recorded with no chance of retracking, you're kinda screwed. A soft gate will help, and some eq, but there's no majic noise removal plugin, it needs to be tracked properly. |
thanks.. rerecording is definately an option..
I am looking into getting into a quieter setting. a friend of mine is soon getting into an apartment, hopefully with a 2nd bedroom and big closet, all for the studio.. I would imagine a closet setting would be pretty quiet away from computer, and ac and everything.. like I said i am using the NTK, so tell me, with that alone, when you hear an acoustic song on cd by itself, is it just really that quiet, the room.. or is there gating and eq going on just to remove noise?? if its soley in the room, then I'll change some things around and get it quiter.. |
its an isolation booth!
I assume the mic itself is not the problem, and you've listened to it. A bad tube can emit what may appear to be backround noise. cheap solutions are utilizing closets, haning blankets, comforters to form a temporary iso booth. the bathroom can work well, with or without treatment, depending on what sound you're going for. Hang a heavy blanket over the whower rod and over the sink to deden reflections, and sit the performer on the throne. |
thanks where.. thats the kinda stuff im looking for..
the mic is near brand new, so the tube should be fine (though I have a backup on hand) Im not in a studio here.. we're dealing with an apartment, so those are the kinda tips i was looking for. i am definately going to try and get in a separate room from the computer. thats why i mentioned the closet. i'll have to wait till we get the place and try it out. now i know its all in the room, so i won't waste my time with eq's and such when that isn't the problem!!! thnx all |
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
-85 db Background Noise , is this normal ? | Barbad | Pro Tools TDM Systems (Mac) | 21 | 07-12-2010 03:00 PM |
Background noise | rmarsh9374 | Tips & Tricks | 10 | 08-31-2009 08:22 AM |
Need help with background noise! | jimthepisces | Tips & Tricks | 14 | 01-21-2009 01:45 PM |
Background noise | paguru | VENUE Live Sound Systems | 10 | 03-20-2007 05:00 PM |
accumulated background noise | tshev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-18-2005 08:46 PM |
