Fan Noise: HD Native With Sonnet Echo Express SE
I'm working with a client's HD Native rig, Sonnet Thunderbolt adapter for the HD Native card. The issue is that the Sonnet fan is pretty loud. Anyone know if I can safely disconnect the fan? The HD Native card is the only card in the adapter. Thanks for your help! Best…H
Re: Fan Noise: HD Native With Sonnet Echo Express SE
Avid Thunderbolt HDN has pretty good aluminum enclosure that takes down the heat. So I suspect the card gets pretty warm if you run it for hours. If you only run it few hours I think it does not matter if it's cooled or not. Up to you how much risk you want to take.
I use the OWC Helios thunderbolt enclosure for my HD|Native and disabled the fan (same issue, it was crazy loud for such a little box).
Have had no issues with it getting too hot, and it's powered on 24/7. From what I read the fans in these enclosures are more for cooling high-end graphics cards with CPU's on them and the like, the HD|Native card doesn't get hot like those do. |
Damn, that's a great idea! I wish I would have thought of it when I had mine. |
I got a reply from Sonnet:
"While we don’t typically advise disconnecting the fans in the units, most audio cards do not generate much heat, so you may not experience any issue with doing so to reduce noise. However, this is something that you will be doing at your own risk, should there be any complications resulting from lack of sufficient airflow." I'm having our tech install a mini toggle to allow disabling the fan. Best…H |
A temperature probe would be a good idea also, at least for the sort term or if it could be set to turn the fan on at a high limit would be even better
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Sonnet Echo Express III-R Thunderbolt PCIe Expansion Chassis | Andi R | Pro Tools HDX & HD Native Systems (Mac) | 22 | 02-05-2014 10:35 PM |
HD native thunderbolt through Echo Express SE Thunderbolt Chassis | hkj1 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 11-06-2013 05:49 PM |
Echo Express III and Echo Express Pro (HD Cards) | Barry Johns | Pro Tools HDX & HD Native Systems (Mac) | 2 | 04-26-2013 07:37 AM |
Thunderbolt-Sonnet’s Echo™ Express PCIe 2.0 Expansion Chassis with Thunderbolt™ Ports | Barry Johns | Pro Tools TDM Systems (Mac) | 29 | 08-11-2012 07:01 AM |
Sonnet Echo Express and HD2: Not working/help | andybabin | Pro Tools TDM Systems (Mac) | 6 | 08-01-2012 05:27 PM |
