Old 09-30-2010, 04:16 PM
crizdee's Avatar
crizdee crizdee is offline
Default Send could not be made active, not enough DSP
Not a huge mix and i'm getting this message whilst trying to activate a send
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-30-2010, 06:51 PM
FajitaTone FajitaTone is offline
Default Re: Send could not be made active, not enough DSP
looks like the top chips are always the mixer chips. you need another card Chris.
Ray Trujillo
Freelance Audio Engineer
Craig F Craig F is offline
? how are you getting 192 voices on 3 chips.
I'm thinking you have a DAE corruption
Thank you,
Craig
Old 09-30-2010, 08:45 PM
kd_special kd_special is offline
You need to get some more bussing power with another DSP card. Or use RTAS.
Or try and clear up some Busses
kd
Old 09-30-2010, 11:49 PM
crizdee's Avatar
This is a HD 6, only the top 3 cards are in view!! i have 6 chips 192 voices and i'm only using 132 voices and i have 380+ time slots left.
I've done mixes 3x this size!! with no issues of running out of DSP.
most likely it will work when i go in today
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-01-2010, 03:57 AM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
Chris
just dealt with this on a mix that i have been working on for 2 years (band comes in intermittently every couple months). So it started in 7.x and primarily it was worked on in 7.4.
Anyways, we were experiencing a TON of those messages in 7.4. Eleven seemed to be the culprit. I deactivated Eleven and we could get some routing going. But in 7.4, when we tried to reactivate Eleven, same issue.
So I loaded the session into 8.1. Still a little squirelly. So I closed it, PT said something about freeing unused DSP, then I loaded a simple session. Closed it. Reloaded the buggy session.... all was ok and has been since. It's worked great ever since PT said something about freeing up unused DSP.
I know little about the super tech side of DSP allocation. but I know 8 opened up the file when 7 wouldn't. You're already on 8. It seems like it needs to open it once the right way so it can remember it the proper way.
doubt it helps but i figured I'd chime in, since it happened to me this week.
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 10-01-2010, 05:15 AM
crizdee's Avatar
Originally Posted by brianjanthony View Post
Chris
Hi Jeremy,
Well today i loaded the session and it said..
Track DLY 2 Insert A (H-Delay) has been made inactive because DAE error was encountered, error 7058.
I loaded the session and tried to activate H-Delay and did the DSP shuffle and has been OK so far
This is by no way a big session!! 12 chips free/ 50 voices free and 380 time slots free.
Just one of those little blips i guess.
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-01-2010, 06:40 AM
Waves... 'nuff said.
glad you got it sorted, sorta.
Good luck.
Ray Trujillo
Old 10-01-2010, 08:31 AM
D'Animation D'Animation is offline
Have had to deal with this on a HD2 with chips to spare - cycling DSP cache seemed to work things out
D
Old 10-01-2010, 01:53 PM
RubyQueen RubyQueen is offline
Chris-
Unrelated to your issue, but: how do obtian the color on the channels? I have been in PT 8 for over a year and not been able to achieve this. Thanks for indulging this query
the output could not be made active because the output path is currently made inactiv rosebartu Pro Tools M-Powered (Mac) 4 03-21-2018 12:28 PM
Plug ins could not be made active because recurces are not available Maddawg383 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-21-2010 11:36 AM
One or more plug-ins could not be made active because there cc1 Pro Tools TDM Systems (Mac) 7 04-30-2010 11:44 AM
888/24 S/PDIF could not be made active? Help! starburst Pro Tools TDM Systems (Mac) 3 01-12-2010 02:43 PM
Plug-in could not be made active... T-Racks.EQ felipe411 Pro Tools TDM Systems (Mac) 4 08-10-2008 04:49 AM
